2002 Neon question
#1401174
03/12/13 08:40 AM
03/12/13 08:40 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
My son called said the car wouldnt start, lights dim, etc. He said in the mileage window ??, it said fuse? I had him look at the fusible links, he said they were good, but in all honesty, he hasn't had the best training from me to know what he is looking at.
He got another battery, put it in, and starts right up, but I think he has an alternator issue not charging the battery. He is 400 miles away, so I cant help him, but i told him to take it to Autozone and have them check the alternator to see if it was charging.
Any hints??
Re: 2002 Neon question
[Re: Dodgeguy101]
#1401175
03/12/13 10:31 AM
03/12/13 10:31 AM
Posts: 12,244 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Fuse will display when you have bad dome light bulb, so fuse doesn't necessarily mean fuse. If the alternator isn't charging right, the battery light usually lights up. Sounds like the battery was bad or there may have been a bad connection. Let us know what the test reveals.
Master, again and still
[Re: Dodgeguy101]
#1401177
03/12/13 09:57 PM
03/12/13 09:57 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I did not mean that the dome light is the source of your trouble. What I was getting at was that fuse was used to indicate a number of different electrical issues. I have always wondered why they used the word fuse.
[Re: DaveRS23]
#1401178
03/13/13 08:07 AM
03/13/13 08:07 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I guess why I posted was, didnt understand why it said fuse on the dash?? He had the timing belt replaced recently, that is why I thought a wire from the alternator may have been rubbing and was shorted out. I'm still not a 100% sure it is fixed by the battery, but will have to see.
He said everything was fine, although he didnt go by autozone to have it checked. I guess I'll know when something is wrong when he calls again.
Women or cars, you get the call....
I do appreciate your help, thanks.
[Re: 71birdJ68]
#1401180
03/13/13 02:44 PM
03/13/13 02:44 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
After living with my Neon since 94, I have found that the battery cables start corroding where the terminals attach and you start loosing voltage, which affects everything. I finally had to replace the battery cables.
Thanks, I'll have him look at those.
[Re: Dodgeguy101]
#1401186
03/14/13 02:14 PM
03/14/13 02:14 PM
Posts: 52 CO
Twisted
CO
I believe there are 2 ground wires that could be disconnected when changing a timing belt. Getting the tension set on the alternator is also a bit of a pain with that threaded adjuster so maybe check for slack on the belt.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
[Re: ahy]
#1401187
03/19/13 06:08 PM
03/19/13 06:08 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
My '98 had that problem (rot, corrosion, whatever) on the negative cable. All kinds of funny symptoms. It had broken down to a couple strands of wire. A cable repair fixed it.
Thanks guys, this was exactly the problem. New cables, good to go.
[Re: ahy]
#1401189
03/20/13 07:07 PM
03/20/13 07:07 PM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
I just changed out all the cables on my '96 for similar reasons.
