Radiator Cap for Truck
#140106
10/22/08 03:54 PM
10/22/08 03:54 PM
My current radiator cap is not high enough pressure. It is leaking to much air. Does anyone know a good PSI/Ft lbs to use?
87' 318
Re: Radiator Cap for Truck
#140108
10/22/08 03:59 PM
10/22/08 03:59 PM
Posts: 778 Omaha,Nebraska
johncambridge
super gas
super gas
Omaha,Nebraska
The factory shipped it with a 16 lb. cap.
BAXTER CHRYSLER JEEP DODGE - OMAHA,NEBRASKA
800-642-1524 - 402-493-0116 - PARTS@PERFORMANCEAUTO.COM
MOPAR PERFORMANCE, RESTORATION PARTS
TTi HEADERS AND EXHAUST DISTRIBUTOR
LEGENDARY INTERIORS DEALER
AR ENGINEERING DEALER
[Re: stumpy]
#140109
10/22/08 04:02 PM
10/22/08 04:02 PM
What are you using now?
It is too worn out and corroded to tell. Would anyone suggest perhaps going a little higher then 16?
[Re: stumpy]
#140111
10/22/08 06:29 PM
10/22/08 06:29 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I wouldn't go any higher. Just replace the one you have with a new one. It's worn out that's why it won't hold pressure.
They maker higher pressure caps, but they are for specialized applications. 16 is plenty for an 87 318. If a new 16lb keeps blowing off, then you have other problems
