Re: mounting alt. with csr water pump
[Re: Pstew]
#1400950
03/12/13 08:06 AM
03/12/13 08:06 AM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
If you switch to a drivers side lower hose radiator, you can. My radiator was new, so I opted to move the alt to the drivers side.
i nave new radiator with pass side lower hose and want alt. in stock location
[Re: Plymouth340]
#1400951
03/12/13 08:26 AM
03/12/13 08:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Are you talking SB or BB... this will give you a idea of the clearance... I cant remember the height of the alt in the stock location.... mine is mounted to the frame rail ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1400952
03/12/13 09:58 AM
03/12/13 09:58 AM
Posts: 1,377 Ohio
Todd
Ohio
![](/ubbthreads/images/graemlins/iagree.gif) Put it on the frame. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: J_BODY]
#1400954
03/12/13 11:07 AM
03/12/13 11:07 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If it's any help, I used the much smaller Neon alternator on mine.
Master, again and still
[Re: Plymouth340]
#1400957
03/12/13 07:43 PM
03/12/13 07:43 PM
MR_P_BODY
so everyone is saying i cant put it in the stock location?
I dont know for fact but if you look at the upper line of the belt I think its gonna hit the water pump... unless the alt is lower than what I think it was in the stock location..... myself I wouldnt run it in the stock location.. the belt would be too long and maybe spit the belt off... a short belt is always better ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Plymouth340]
#1400959
03/12/13 08:09 PM
03/12/13 08:09 PM
MR_P_BODY
yea a shorter belt would be a good idea. so if i move the alt i wont haave to worry about the water pump...
Correct... move it down ![](/ubbthreads/images/graemlins/wave.gif)
[Re: AndyF]
#1400964
03/13/13 12:13 AM
03/13/13 12:13 AM
Plymouth340
CEDAR RAPIDS
My SB motor plates come with a built in mount for a small Powermaster alternator. The small alternators will fit in between the motor plate and the K-frame. My setup hangs the adjusting strap from the motor plate also so it is a self contained unit.
got a picture?
