Re: Narrowing an 8 3/4, what did you guys do for axles??
[Re: smokes]
#1400906
03/11/13 01:32 PM
03/11/13 01:32 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I called Doctor Diff and ordered a set for the shorten housing.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: smokes]
#1400907
03/11/13 01:50 PM
03/11/13 01:50 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Just did the same thing on a 69 Dart. Order the A Body 4 1/2" bolt pattern conversion axles from Doctor Diff. They are splined deep enough that you can shorten them. We shortened the ones I bought 1" on each side.
...FAFO...
[Re: smokes]
#1400908
03/11/13 03:51 PM
03/11/13 03:51 PM
RapidRobert
I sent a 1/2 ton truck 8&3/4 housing/axles in to Moser in Portland Indiana for shortening to A body specs. As far as axle selection they informed me that if you hook a tape over the flange & have 28" or more out to the end till the axle starts to taper that you have a suitable candidate for narrowing to stock A body width & less than 28" if you are going shorter than stock A body width. there can be a stackup of tolerances & if I was to do it over again I'd mockup the axles with foam/steel gaskets/backing plates sans 3rd member & measure the distance between the axle ends in the bare housing & give Moser that dimention
