Anyone run a auto? #1400521
03/10/13 11:05 PM
03/10/13 11:05 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
It was brought to my attention today that maybe a t56 may not be the best idea
The r48h can be built to take real power they have a manual valve body for it it's a lock up Convertor it's over drive. Sounds like a good deal.
Ill run 354 gears and 28-29" tires and make atleast 800hp
2.45
1.45
1.00
.69
Re: Anyone run a auto? [Re: joshking440] #1400522
03/11/13 12:54 AM
03/11/13 12:54 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Nope, 833 is the only way for me. Gotta play with a stick!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone run a auto? [Re: astjp2] #1400523
03/11/13 12:55 AM
03/11/13 12:55 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Carefull how you say that, you MIGHT get a new title, "plays with 'sticks' ".
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Anyone run a auto? [Re: joshking440] #1400524
03/11/13 01:13 AM
03/11/13 01:13 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I like the 727 with the GV overdrive. I know that most will claim that REAL men shift for themselves, but I like automatics AND am quite manly.
Re: Anyone run a auto? [Re: Kern Dog] #1400525
03/11/13 03:45 AM
03/11/13 03:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you are running an autocross event, you're just going to leave it on gear anyways. Especially with that monster motor. There are SoloII National Champs with V-8 sedans that run automatics.
On a fast road course with not a lot of slow tight parts and with that motor, not as big a deal as with other motors. Not 100% optimal, but it's not going to blow up and explode with an automatic.
Re: Anyone run a auto? [Re: amxautox] #1400526
03/11/13 05:04 AM
03/11/13 05:04 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I'm married so its my stick since my wife wont claim it.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Anyone run a auto? [Re: autoxcuda] #1400527
03/11/13 06:34 AM
03/11/13 06:34 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You mentioned "not a lot of slow tight turns" seems like an auto would be OK with that, or is your concern braking?
Re: Anyone run a auto? [Re: jcc] #1400528
03/11/13 10:43 AM
03/11/13 10:43 AM
Indy
Lunch is on me!
Lunch is on me!
Indy
Do these clubs frown on traction control
Re: Anyone run a auto? [Re: joshking440] #1400529
03/11/13 11:46 AM
03/11/13 11:46 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Auto, manual valve body and GV's here.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Anyone run a auto? [Re: joshking440] #1400530
03/11/13 12:09 PM
03/11/13 12:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No.
All those new SRT8 cars live by it. But I think that active? traction control might more involved that what you plan on running. I know there's some new guys that come out with us that are sort of re-learning thier cars with the traction control turned off.
Re: Anyone run a auto? [Re: jcc] #1400531
03/11/13 12:21 PM
03/11/13 12:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
A little, but also the avoiding the many up and down shifts. It's a bigger deal with something say a 4 cly Neon that would needs to be in the revs.
What is your feelings on this MS68EFI?
Re: Anyone run a auto? [Re: autoxcuda] #1400532
03/11/13 01:15 PM
03/11/13 01:15 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I agree completely. So many factors go into this decision. I personally have had no issues with this set-up. We make 600 ft.lbs of torque, so my RPM range is lower and allows for minimal issues between shifts. There will always be a certain amount of driver skill needed to really take a car hard into a corner, manual or auto. I really use my Gear Vendors to my advantage on road course, even under braking. I suggest running your brake bias contols into the cockpit area, it helps on longer runs with a big car.
Re: Anyone run a auto? [Re: Viol8r] #1400533
03/11/13 02:32 PM
03/11/13 02:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... I really use my Gear Vendors to my advantage on road course, even under braking. I suggest running your brake bias contols into the cockpit area, it helps on longer runs with a big car.
So do you gear split on upshifts and downshifts?
Re: Anyone run a auto? [Re: autoxcuda] #1400534
03/11/13 02:56 PM
03/11/13 02:56 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Yes, as much as possible. It does take some getting used to but if you are on a part of the course where 2nd gear is optimun you are basically just turning the unit off and on.
I run a button on my Cheetah shifter, right in my thumb position. It's like a Sunday drive!
7621938-Shifter.pdf (83 downloads)
Re: Anyone run a auto? [Re: joshking440] #1400535
03/11/13 06:02 PM
03/11/13 06:02 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
The 47 and 48 RH/E transmissions are tanks, there is no manual detent position for overdrive. If you end up going to JW ultrabell route to adapt it to your engine, the ultrabell will only fit a 10" converter - which isn't mentioned anywhere. Not many people make a lockup converter that is 10". Getting someone to build a lockup converter that will take real power will probably require a midplate/spacer, so factor that in when you cut the tunnel/crossmember to fit it in there. This trans can be made as strong as you need it to be but if I had to do it over again I'd go with a GM conversion trans. Much more aftermarket support.
Re: Anyone run a auto? [Re: joshking440] #1400536
03/11/13 06:11 PM
03/11/13 06:11 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Why is a manual not the best idea?
How about a G-Force GF-5R 5-Speed or Jerico 5 speed?
Dog Rings and Sliders can be fun.
Re: Anyone run a auto? [Re: RTSE4ME] #1400537
03/11/13 07:19 PM
03/11/13 07:19 PM
In Limbo
Billy B Bad Offline
Billy B Bad  Offline
In Limbo
This build will be interesting, please keep us (me) updated on how it goes
Re: Anyone run a auto? [Re: Billy B Bad] #1400538
03/11/13 11:10 PM
03/11/13 11:10 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
During a med-speed typical pylon lot autocross, you want to avoid shifting so you won't disrupt the driving and transition of the car. On a hi-speed road course you have more time in the straights (although some may still be curved straights) to aford the shifting. A manual trans will allow more power to be used, whereas the automatic does take some away. Regardless which type of course you're on (med-speed r hi-speed), and which type of trans you have, you want to avoid disrupting the flow and steadiness of the car if/when ever shifted... try to concentrate on being smooth. My 727 has been bullet proof and it shifts fully automatic or manual up/down... I can trail brake more easily with an automatic, but manuals take more skill to master their advantages. Winners can be either trans (auto or manual)... the nut behind the wheel makes the final decision on how well the car finishes.
Re: Anyone run a auto? [Re: Mopar Mitch] #1400539
03/11/13 11:23 PM
03/11/13 11:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So is a well set-up auto smooth enough? Seems like a quick change rear end is the real answer for different tracks.
And to the OP, I'd put a deposit on the passon 5 spd and call it a day, run anything in the meantime to sort out car and driver first.
Re: Anyone run a auto? [Re: jcc] #1400540
03/11/13 11:29 PM
03/11/13 11:29 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
A new iron curtain drawn across the 49th parallel
