Roll cage question for a Coupe #1400415
03/10/13 06:51 PM
03/10/13 06:51 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Is there a way to build a NHRA legal (8.50 and slower) cage for a coupe like this without the rear down bars poking thru the rear of the body? Are the angled rear down bars required, or what is the alternative?
I'm toying with the idea of building this '31 Plymouth for the Drag Week Hot Rod Class.
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Roll cage question for a Coupe [Re: Hemi_Joel] #1400416
03/10/13 09:21 PM
03/10/13 09:21 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I ran into this with a truck I was doing for a customer. Yes, basic cage has to have the down bars per NHRA. If you go to a funny car spec type cage you do not have to have them.
My recommendation is.. You fit the hoop right behind the doors. Build a hooped seat bar that goes behind your seats. Then bend the rear suport bars to curve behind your head and seat down to the seat bar. From the seat bar you can go through the trunk firewall to the frame. You could get creative with this and do just the rear portion of a funny car cage. The NHRA rulebook has some pictures of roadster cages. They are similar in shape to what I have in mind.
Just remember the reason for these rear bars is to keep the cage from flipping out of the car with a rollover and hard roof impact. Such as sliding down the track 100 MPH and hitting something stationary.
Leon
Re: Roll cage question for a Coupe [Re: Hemi_Joel] #1400417
03/10/13 09:33 PM
03/10/13 09:33 PM
I love the early Chysler hemi My first real half fast hotrod had a 1955 Chrysler 331 C.I. out of a New Yorker in it. It was in a 1933 Ford Pickup with a three inch chopped top, it had been channeled four inhces over the frame so it was a little tight inside with me and missus in it I didn't realize that the 1931 Plymouth cuope had standard opening doors I was offered a 1934 Dodge cuope for free from a couple who where going through a divorce but I turned it down because I thought it had suicide doors on it like the 1932-34 Plymouth and Fords had I found out later after it was to late that it didn't either Have fun and enjoy that rascal
Re: Roll cage question for a Coupe [Re: Cab_Burge] #1400418
03/10/13 11:53 PM
03/10/13 11:53 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
How bout you get that Hemi back together first
Re: Roll cage question for a Coupe [Re: Leon441] #1400419
03/11/13 12:12 AM
03/11/13 12:12 AM
MN
hemidup Offline
hemidup  Offline
MN
Leon
The funny thing about NHRA rules is its "all or nothing" attitude. I race my daily driver 2005 Hemi Ram pickup. Comes in a tad over 5200lbs and will run a high 10 on a good day. I planned on installing a 5 pt roll bar so my wife could climb in and out the passenger side with ease, but being a regular cab truck I would need the rear bars to exit out the back window. So then I talk to NHRA and asked them if I kept my e.t's in the 11.80 zone and put in a 4 point cage without rear bars would that be fine? They told me I need to have a funny car cage installed if I didn't want the rear bars. They told me if I showed up at the track with a 4pt roll bar without rear bars, even if my truck ran a 16 flat, they wouldn't allow me make a pass. I questioned them and said a 16 sec vehicle doesn't require a roll bar. They told me it was all or nothing. I told them I'd feel more comfortable with some protection vs none. Sooooo, hopefully my factory seat belts, shoulder strap and factory engineered designed cab will keep me safe if I end up on the roof at a 100mph plus at the beg end.
Jerry Williams.
Re: Roll cage question for a Coupe [Re: hemidup] #1400420
03/11/13 09:39 AM
03/11/13 09:39 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Build a funny car style cage
Re: Roll cage question for a Coupe [Re: B G Racing] #1400421
03/11/13 12:02 PM
03/11/13 12:02 PM
Minnesota
Minnesota
Thanks for the replys!
THis would be a street car, I am concerned that a funny car cage would make it no fun as a street car.
I need something more like a normal roll cage, like what you put in when you hit 9.99 ET.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Roll cage question for a Coupe [Re: Hemi_Joel] #1400422
03/11/13 01:57 PM
03/11/13 01:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You dont have to build it like a typical Funny car cage,just put the main hoop forward the driver and the cross bar behind the seats and curve the bars back from the main hoop to the cross bar.You must support the cross bar at or near where you attach the two rearward Funny car syle hoops to the frame.
Re: Roll cage question for a Coupe [Re: B G Racing] #1400423
03/13/13 04:56 PM
03/13/13 04:56 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Joel,
Have you looked at the NHRA rules for a "Street Roadster"? They are convertible, left hand drive. I can't seem to find my rule book, and it's a few years old at least, but I seem to remember the roll-bar configuration to be less than FC, but more than a typical cage.
BTW, I love the coupe. It looks like a nice car, and more of a traditional car. I know you build fast stuff, but will this thing go faster than 10.0??? If not a bar will suffice with no halo or dash-bar. Good luck either way.
Re: Roll cage question for a Coupe [Re: Tommy D] #1400424
03/13/13 10:16 PM
03/13/13 10:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
We are not talking a full funny car cage. Not even a helmet bar. But, the main hoop will be over your head instead of behind it.. This means instead of coming off the level top portion of the hoop with two rear support bars not less than 30 degrees or whatever the book states you do something else. What we are suggesting is bending the seat back brace bar. If you took a yardstick and stood it up against your rear window the seat bar would be just inside the stick. Then you build your rear support brace to curve around the back of your helmet and but into the seat back brace. Then you follow on the other side down to your frame. Then another bar to the rear from the same joint over the seat back brace. This does not constitute a funny car cage but the shape of the bars you use are the same as some used in a funny car cage.
Leon
