aftermarket water temp gauge in '04 5.7 Ram? #1400239
03/10/13 02:47 PM
03/10/13 02:47 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
has anyone installed an aftermarket water temp gauge in their 5.7 ram?
Im not clear on where to install the sensor, the installation kit recomended drilling the head, No Thanks!
Re: aftermarket water temp gauge in '04 5.7 Ram? [Re: LimeliteAero] #1400240
03/10/13 03:38 PM
03/10/13 03:38 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Maybe 1 of the block drain plugs on either side of the block or in an in-line adapter that goes in the rad hose??? Good luck.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
