I'd say take it to a shop for an inspection, but if you already tore it down, you're SOL there.
If its apart, it will be difficult to determine the condition of potentially good parts. If you've gto it all apart, you probably should consider replacing all the joints and bushings in it so that it is only done once, even if the cost is a bit higher.
You can get a fairly complete kit from PST with all the bushings, links, and ends for around $250. IIRC, this will not include the inner tie rod ends and an idler arm, but you can add those to the kit for a few dollars more.
