Who sells axle / brake backing plate STUDS for rear end #140020
10/22/08 11:26 AM
10/22/08 11:26 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
If I want new studs and nuts for a rear end build, where do I get them?
The ones that you bolt the axle retaining plate / brake backing plate with? 5 on each side.
Re: Who sells axle / brake backing plate STUDS for rear end [Re: LAR_414] #140021
10/22/08 11:40 AM
10/22/08 11:40 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I never did find A source for those when I was building my rear end for the first time. After endless searching I opted to drill and tap the holes for heli coils for a 5/16 bolt.
I've never had any issues with them and I acctually like it better than the studs when I have to go in there.
Just my in case you cant find them either.
Re: Who sells axle / brake backing plate STUDS for rear end [Re: LAR_414] #140022
10/22/08 12:01 PM
10/22/08 12:01 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I stock those parts.
Re: Who sells axle / brake backing plate STUDS for rear end [Re: DoctorDiff] #140023
10/22/08 12:08 PM
10/22/08 12:08 PM
LAR_414 Offline OP
LAR_414  Offline OP
I'll be sending you an e-mail.
Re: Who sells axle / brake backing plate STUDS for rear end [Re: LAR_414] #140024
10/22/08 01:47 PM
10/22/08 01:47 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Larry,we just take a quality 3/8 bolt and grind one flat off the head.Works great if yo also need a longer bolt.I may have some stock ones lying around the shop.
Re: Who sells axle / brake backing plate STUDS for rear [Re: B G Racing] #140025
10/22/08 02:01 PM
10/22/08 02:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think Dr. diff has them ?
Re: Who sells axle / brake backing plate STUDS for rear end [Re: B G Racing] #140026
10/22/08 02:07 PM
10/22/08 02:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The studs I sell are longer than stock, so they work with all disc and drum kits.
The shank is knurled, so they don't fall out or flop around when you install the brakes.
Re: Who sells axle / brake backing plate STUDS for rear end [Re: DoctorDiff] #140027
10/22/08 02:59 PM
10/22/08 02:59 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
You can also get them from Mopar under part # 3723668 bolt and 6030310 nut. Both are in stock
Re: Who sells axle / brake backing plate STUDS for rear end [Re: rt66jim] #140028
10/22/08 03:03 PM
10/22/08 03:03 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What is list price on those studs?
Re: Who sells axle / brake backing plate STUDS for rear end [Re: DoctorDiff] #140029
10/22/08 03:28 PM
10/22/08 03:28 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
$2.80
