Pot Metal & Plastic Chroming - Need Recommendations! #1400187
03/10/13 02:02 PM
03/10/13 02:02 PM
Northern VA
bulletpruf Offline OP
Northern VA
Fellas -
Anyone have a recommendation for pot metal chroming? Looking for someone reliable who won't charge me an arm and a leg for some small stuff. Needs to be very nice, but I'm not after perfection.
Here's what I have so far:
Advance Custom Chrome, Erie, PA
Paul's Chrome - http://www.paulschrome.com/ - Evans City, PA;
Iverson Automotove - http://iversonautomotive.com/index.html - Minnesota;
Advanced Plating in Nashville TN (800-588-6686) - I believe this is the place I heard about that's quite expensive, but does fantastic work.
Any recommendations on plastic chroming? I used CV platers in the past, but they're out of business.
Thanks!
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: bulletpruf] #1400188
03/10/13 02:19 PM
03/10/13 02:19 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
I have had my pot metal stuff done at Reckon Plating in Fort Wayne, with good results and my plastic stuff I think we used redline gauges in California.
I don't imagine any chrome shop would be inexpensive today, their costs have escalated along with everything else.
Good Luck!
Joey
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: jake4cars] #1400189
03/10/13 02:24 PM
03/10/13 02:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Glen Baughman at www.gcartrim.com for plastic chrome plating. He was tight with CV Platers, even bought some of thier eqipment, he's VERY good at it and competitively priced.
QUALITY Chromed pot metal restoration that doesn't cost an arm and a leg? Good luck with that! I've seen Iversons work, he's very talented. The work is like body work, the old plating is stripped, the pits are revealed, the pits are filled, then the bondo (copper) goes on and is polished and worked to a perfectly smooth surface before nickel and chrome plating. It's tedious time consuming work and you need to be VERY good at it to properly restore (and avoid ruining) a part to a show worthy level.
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: ScottSmith_Harms] #1400190
03/10/13 06:06 PM
03/10/13 06:06 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Whoever you go with, make sure you clearly understand the process. If they say they'll plate the heck out of it with copper to fill the pits, run away fast. If they say they will use bondo or some other sort of plastic filler for the pits, run away fast. Pot Metal is crap metal to start with and wasn't designed to really last. The cleaner your cores the better, but don't give your best cores to someone unless they did good work before on some or your not so good pieces. And stay away from NuChrome in Falls River, Mass..DAMHIK...,
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: bulletpruf] #1400191
03/10/13 06:35 PM
03/10/13 06:35 PM
I use S&H Chrome Plating in Madison, Tennessee. Phone: (615) 865-0100
Reasonable prices, excellent work, including pot metal. They have a booth at the Moultrie, GA swap meet, November and February of every year.
Re: Pot Metal & Plastic Chroming - Need Recommendations! #1400192
04/07/13 02:58 PM
04/07/13 02:58 PM
Northern VA
Northern VA
Thanks, fellas. Appreciate the input.
Scott
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: bulletpruf] #1400193
04/07/13 05:11 PM
04/07/13 05:11 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I used Iverson for customers 52 Buick grill. The first time through was unacceptable and he re did it with no problem. Awesome work, not cheap but awesome. On thing that did concern me was his requirement for 1/2 up front and he is a one man operation. What happens to the part(s) and money if something happens to him????
Re: Pot Metal & Plastic Chroming - Need Recommendations! [Re: bulletpruf] #1400194
04/07/13 05:42 PM
04/07/13 05:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...Small Family run shop, specializes in Custom work, not a sideline like some of the larger platers, they offer a wide range of services, plastic included...you get what you pay for when it comes to plating, and their prices aren't that bad, I've payed more in the past to other vendors for so-so work/quality
mike
