Re: Ran the 440 small block Dakota - Thoughts?
[Re: ADakotaRTGuy]
#1400029
03/12/13 12:18 PM
03/12/13 12:18 PM
Posts: 901 oh
julian2007
oh
anyone who says your dakota is not bad fast for what it is does not race.make no mistake that ting is fast for what you have in it.I am the frist to call bull $hit on someont when they start with 3900 lb race cars but I know what those dakotas weigh.440 small block+3900 lbs running 11.20's = FAST
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: ADakotaRTGuy]
#1400030
03/12/13 12:25 PM
03/12/13 12:25 PM
Triple Threat
Renton Washington
I agree that truck is fast, using the old rule of thumb 100# = .10, subtract 1000 pounds and its a low 10 second ride.
That's fast with low compression, not a ton of camshaft, and mild gears. Especially on the first day out, it will go faster with tuning i'm sure.
Be proud of what you have there, it is a nice piece.
[Re: Triple Threat]
#1400031
03/12/13 04:05 PM
03/12/13 04:05 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Generally power adders (depending on what type of power adder) will use a much different gear, converter, compression ratio, cam...
For instance, mine is 3.55 geared w/30" tall tire, 3000 converter, 9:1 compression, cam with 0 overlap, shifting at 6000 rpm. This is all because it is set up for turbo and would probably run 12.0 on motor only.
[Re: julian2007]
#1400032
03/12/13 04:10 PM
03/12/13 04:10 PM
Posts: 193 MD
ADakotaRTGuy
MD
Julian, that is a nice truck. What is done to yours?
[Re: ADakotaRTGuy]
#1400033
03/12/13 07:03 PM
03/12/13 07:03 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I'm not trying to knock what you've done. I hope that doesn't come off that way. I'm just telling you that you should figure out what's wrong so you can get the most out of your combo. If this one made 470hp to the tire, it probably makes 550~575 at the crank. Just look at some other combo's. Here is a 340" with unported w9's that made 602hp on pump gas. http://www.moparmusclemagazine.com/techarticles/engine/mopp_0310_340_engine_600_hp/viewall.htmlThere is no reason why your's shouldn't make more power then this. Even if this one has more compression, your heads are MUCH better then an unported w9. Like I said... sorry if it came off like I was knocking you. I was just trying to help.
[Re: dizuster]
#1400034
03/12/13 07:08 PM
03/12/13 07:08 PM
Posts: 193 MD
ADakotaRTGuy
MD
That is all great, but you are missing one important part. Those are 48 degree heads. They flow as much as mine out of the box and can go much much higher.
