Heavy Duty aftermarket tie rod ends for W250?????? #1399939
03/10/13 12:56 AM
03/10/13 12:56 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
I sure you guys running large Off road tires have experienced the limited life of "factory" replacement parts,...I've searched everywhere (I think?) for either heavy/severe duty tie rods, and or a complete tierod/bar assy that will last more than a year!...my daughters truck eats these things on a yearly basis, the truck is a 87 Dodge W250 front axle is a Dana 44, 6" lift springs 37X12.5X17 TSL Thornbirds, seems the aftermarket really has abandoned the 70-80's Dodge truck line in favor for the new Rams...anybody have a source or cure for the rod ends on a 4X4?
mike
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: DAYCLONA] #1399940
03/10/13 01:07 AM
03/10/13 01:07 AM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
I only have two answers. One, put a Dana 60F under it.
Put a less aggressive, radial tire on it, and it would probably let the rod ends live longer.
I myself could not drive a Dana 44 truck with 37" tires across town without breaking an axle shaft, tie rod ends were the least of my worries back in the day before I had a 60F.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: MMiller] #1399941
03/10/13 03:45 AM
03/10/13 03:45 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I agree. With that size tire a D60 is almost a must. 35s are about the limit but Id only run 33s myself on a D44.
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: MMiller] #1399942
03/10/13 06:00 PM
03/10/13 06:00 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
The axle is not an issue, the tires will remain, I have no issues with any of the front end components other than the tie rods, this vehicle has been running these tires daily for about 3 years now, it just seems that the tierods are rather undersized, I'm looking for an aftermarket rod end or bar assy that can replace the OEM components that are severe duty rated
Mike
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: DAYCLONA] #1399943
03/10/13 09:30 PM
03/10/13 09:30 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
The main reason for you that I recommended the 60 is the fact that the steering tie rod ends are huge compared to the 44 offerings, sorry I got off the track of reasons for the 60.
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: DAYCLONA] #1399944
03/10/13 11:06 PM
03/10/13 11:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Mike
Mike I would compare a dana 60 to a 44 ends taper. You could taper ream to the larger size if needed. You also could compare the gm 1987 and older ends. The cross tube is easy enough to fab up.
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: NITROUSN] #1399945
03/11/13 12:35 AM
03/11/13 12:35 AM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Mike
I thought of going this way Pete, and already compared the rod ends, but I thought I'd ask for some ideas, or input on an aftermarket replacement before modding the taper in the arms
Mike
Re: Heavy Duty aftermarket tie rod ends for W250?????? [Re: DAYCLONA] #1399946
03/11/13 08:58 AM
03/11/13 08:58 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Tire size is probably why they wear so fast. Lucky nothing else has wore out yet. Always hime joints
