39 Dodge 4 dr wheels and tires? #139974
10/22/08 10:24 AM
10/22/08 10:24 AM
Anonymous OP
Anonymous OP
I have a question about wheel and tire combo for my car. I just got an 8 3/4 out of a '69 300 and got a line on some 15x10 rear wheel and tires. Problem is I do not currently have rear fenders so I am unsure if they will fit with out rubbing the fenders. Can anyone tell me if they will fit or what is the widest I can go?
Thanks in advance Adam
Re: 39 Dodge 4 dr wheels and tires? #139975
10/22/08 10:31 AM
10/22/08 10:31 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Hard to determine without knowing the offset of the wheels.
Re: 39 Dodge 4 dr wheels and tires? #139976
10/22/08 10:47 AM
10/22/08 10:47 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
the 300 rear end is wider than a B body rear end.
a B body rear fits pretty good in those cars, I think between the width of the 300 rear end and a 10" wheel even with 4 1/2" rear spacing that you will rub the fenders
personally I think a 10" wheel is to wide for your car unless you tub the car or widen the fenders. Ron...
Re: 39 Dodge 4 dr wheels and tires? [Re: bohmer2] #139977
10/22/08 10:52 AM
10/22/08 10:52 AM
Anonymous OP
Anonymous OP
The offset is 3.75.
Re: 39 Dodge 4 dr wheels and tires? [Re: Mopar Ron] #139978
10/22/08 10:54 AM
10/22/08 10:54 AM
Anonymous OP
Anonymous OP
That is what I thought, but wanted to ask to get some opinions. Thank you for your advice.
Re: 39 Dodge 4 dr wheels and tires? #139979
10/22/08 11:09 AM
10/22/08 11:09 AM
Mopar Ron Offline
Mopar Ron  Offline
I built a 37 sedan for a guy years ago and I used a B body rear end with 8" wheels and it just fit and I think the wheels had 4 1/2" back space.... Ron
Re: 39 Dodge 4 dr wheels and tires? [Re: Mopar Ron] #139980
10/22/08 09:15 PM
10/22/08 09:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Those rear fenders are not very wide, I would not expect a 10" wide wheel to fit at all. They would either hit the body or the fenders. I had 15 x 7" on my 39 coupe and they fit nicely with the wheel centered in the fender. Gene
Re: 39 Dodge 4 dr wheels and tires? [Re: poorboy] #139981
10/23/08 12:12 AM
10/23/08 12:12 AM
Anonymous OP
Anonymous OP
If you wanted to run the wider tires in back you could always section your rear fenders, add a little steel and widen them a bit. Either that or tub the back and get rid of your trunk area all together. That way you could fit some fatty's under there.
Re: 39 Dodge 4 dr wheels and tires? #139982
10/24/08 04:08 PM
10/24/08 04:08 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I am using a 68 Coronet rear on my 36 Plymouth. The wheels are from a new Dodge Magnum, 17x7, tires are 275/60/17. There is very little clearance, I will change to 255's or 245's when I change gears to 3:55.
Re: 39 Dodge 4 dr wheels and tires? [Re: 36PLYM] #139983
10/24/08 09:46 PM
10/24/08 09:46 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Any pics of how those fill the fenders?
Re: 39 Dodge 4 dr wheels and tires? [Re: Flipper1938] #139984
10/25/08 02:38 PM
10/25/08 02:38 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Here are some pics of the tires and rearend, The 275's are 30 inches in diameter.
Re: 39 Dodge 4 dr wheels and tires? [Re: 36PLYM] #139985
10/25/08 02:39 PM
10/25/08 02:39 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
Another pic.
Re: 39 Dodge 4 dr wheels and tires? [Re: 36PLYM] #139986
10/25/08 05:49 PM
10/25/08 05:49 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
It looks like that might be the perfect size tire to completely fill the fenders.
If the rear suspension was 3 inches lower, would the tires still clear? or will they rub.
Re: 39 Dodge 4 dr wheels and tires? [Re: Flipper1938] #139987
10/25/08 06:10 PM
10/25/08 06:10 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I believe they would rub slightly. My plan is to go with a 29 inch diameter tire and lower 2 inches with a set of posies.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: 39 Dodge 4 dr wheels and tires? [Re: 36PLYM] #139988
10/26/08 11:26 PM
10/26/08 11:26 PM
Indiana
P
Pentastar440 Online content
Pentastar440  Online Content
P
Indiana
What do you do about the pinion offset when using a B-Body rear end ? I have a '38 Plymouth 4dr sedan that I would like to install a 440 and use a Dana 60 or 8-3/4 . Would the engine have to be installed offset like a B-Body to match the pinion offset , or would the rear end need to be narrowed to center the pinion with no offset ?
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 39 Dodge 4 dr wheels and tires? [Re: Pentastar440] #139989
10/27/08 12:28 AM
10/27/08 12:28 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Your 440 will likely need to be offset to clear the steering, so the axle shouldn't be much of an issue. Your biggest concern will be driveshaft clearance through the center X member. Also, the u-joints in the driveshaft will allow the trans centerline to be offset (as much as 30 degrees) to the rear axle centerline, as long as they are parrellel with each other. Gene
