39 Dodge 4 dr wheels and tires?
#139974
10/22/08 10:24 AM
10/22/08 10:24 AM
I have a question about wheel and tire combo for my car. I just got an 8 3/4 out of a '69 300 and got a line on some 15x10 rear wheel and tires. Problem is I do not currently have rear fenders so I am unsure if they will fit with out rubbing the fenders. Can anyone tell me if they will fit or what is the widest I can go? Thanks in advance Adam
Re: 39 Dodge 4 dr wheels and tires?
#139976
10/22/08 10:47 AM
10/22/08 10:47 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
the 300 rear end is wider than a B body rear end. a B body rear fits pretty good in those cars, I think between the width of the 300 rear end and a 10" wheel even with 4 1/2" rear spacing that you will rub the fenders personally I think a 10" wheel is to wide for your car unless you tub the car or widen the fenders. Ron...
[Re: bohmer2]
#139977
10/22/08 10:52 AM
10/22/08 10:52 AM
[Re: Mopar Ron]
#139978
10/22/08 10:54 AM
10/22/08 10:54 AM
That is what I thought, but wanted to ask to get some opinions. Thank you for your advice.
[Re: 36PLYM]
#139983
10/24/08 09:46 PM
10/24/08 09:46 PM
Posts: 228 Kentucky
Flipper1938
Kentucky
I am using a 68 Coronet rear on my 36 Plymouth. The wheels are from a new Dodge Magnum, 17x7, tires are 275/60/17. There is very little clearance, I will change to 255's or 245's when I change gears to 3:55.
Any pics of how those fill the fenders?
[Re: Flipper1938]
#139987
10/25/08 06:10 PM
10/25/08 06:10 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I believe they would rub slightly. My plan is to go with a 29 inch diameter tire and lower 2 inches with a set of posies.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#139988
10/26/08 11:26 PM
10/26/08 11:26 PM
Posts: 414 Indiana
Pentastar440
Indiana
What do you do about the pinion offset when using a B-Body rear end ? I have a '38 Plymouth 4dr sedan that I would like to install a 440 and use a Dana 60 or 8-3/4 . Would the engine have to be installed offset like a B-Body to match the pinion offset , or would the rear end need to be narrowed to center the pinion with no offset ?
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
