Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399693
03/11/13 07:09 AM
03/11/13 07:09 AM
Delray beach, Florida
P
Performance Only Offline
P
The end play is set at .015thou. I understand the timming cover may flex a little if the button runs against it.
Correct me if I am wrong but dosnt the turning of the dizzy/oil pump drive force the cam to the back of the block, I thought this is what the torrington on the back of the timmig gear set was for?
Tim
On a B/RB/Hemi, the cam is pushed forward. The torrington bearing is useful if your cam end play is run without enough end play and will help to stop premature wear on the face of the block. Otherwise the torrington is almost useless on a big block.
Smallblocks will push the cam to the rear since the distributor is mounted on the opposite side of the cam.
machine shop owner and engine builder
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Performance Only] #1399694
03/11/13 10:40 AM
03/11/13 10:40 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
You guys have been hanging around chevys too much with this cam walk. A b engine cam is forced into the block by the resistence of the oil pump not out. Now it MIGHT walk out at idle but not under throttle. The thrust surface is on the back of top gear, right. As for wearing check for lining up , centered up and down, sounds like mismatched some how.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: cudaman1969] #1399695
03/11/13 05:04 PM
03/11/13 05:04 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
and the roller cam lobes are flat in relation to the centerline of the cam so there is no lobe taper to force the cam in one direction or the other.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: John_Kunkel] #1399696
03/11/13 06:03 PM
03/11/13 06:03 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Yeah. I hang around chevy guys, ford guys, pontiac guys, buick guys, so what does that mean? If you spin your roller cam engine in the direct of operation, with the dizzy drive out, and the lifters on the lobes, it will walk the cam up to the front of the block, and you can visually see what will happen with the roller lifters vs the lobe when it does. Oil pumps and drives on a bb mopar are driver front. dizzy gear on drivers side and counter clockwise timing. Dizzy on chevies is in back and clockwise rotating. Mopar sb is counter clockwise to but on the other side right?
You don't wear out the block face on a bb mopar, it is very rare to do, but you will see a bunch of mopars failures or damaged when the cam went forward. If you don't get the lateral travel right, a failure will happen sooner or later.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399697
03/11/13 06:28 PM
03/11/13 06:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do you think Chrysler would design the cam to (walk) out of the block? The front gear is oiled by the front cam journal. Look at a cam and the lifter rides to the back of the lobe therefore pushing the cam in not out. Take the oil pump off put dist.gear in and lock it so as not move then turn the cam, see which way cam moves. There could have many reasons you'rs walked out but who knows ask a chevy guy they know everything.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: cudaman1969] #1399698
03/11/13 06:49 PM
03/11/13 06:49 PM
P
P
So i guess a lot of people have wasted a lot of money worrying about putting a cam button on a roller cam in a big block mopar? Ummm, No, I don't think so.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: cudaman1969] #1399699
03/11/13 07:07 PM
03/11/13 07:07 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My roller cams, the lifter rides in the center of the lobes. Not the back. Everything in cars and for that matter everything is engineer'd that doesn't make them perfect. Chrysler didn't engineer the slant six to kick rods out of the #6 cylinder either,taking out the starter, but it will. I am going on what I see, what I experienced and what has been seen as failures. If it was pushed backwards, there would be all kinds of posts over the yrs asking what to do when your mopar keeps eating up the back of the sprocket and the front of the block. Chrysler didn't design the old mopars to run on a roller cam either, they were designed with flat tappets and hydraulics. We all can debate on here, it creates options, but bottom line, like most complaints, the cover was flexing or the cam went north not south, and it isn't the first or last time. If something is not controled, then it will be out of control.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Performance Only] #1399700
03/11/13 07:28 PM
03/11/13 07:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Roller cams are not flat Tappets, not ground the same. It is good insurance to put a button in a roller app. not in a hdy. We could pi!! all day over this but to the question The guys cam is alignment problem like a rear end gear.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399701
03/11/13 07:28 PM
03/11/13 07:28 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ill post up a pic of a stock cover that was properly "set up" but you can clearly see where there is a circular mark left by the button putting stress on that cover. It wasnt just "kissing" it either...
MB
Re: Bronze dizzy gear faliure in Hemi need help! [Re: HPMike] #1399702
03/11/13 07:36 PM
03/11/13 07:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
MB
The cam changes direction when its accelerated to
decell (moves in or out)
Re: Bronze dizzy gear faliure in Hemi need help! [Re: MR_P_BODY] #1399703
03/11/13 07:55 PM
03/11/13 07:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ya mean I spent money on a good cover, bought and farted around with four different buttons, two different gasket thicknesses, assembled, measured, disassembled, then did it all again trying to get just the right endplay ... and I did all that for nothing ?!? Sheeeet!
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Stanton] #1399704
03/11/13 08:54 PM
03/11/13 08:54 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Teamx, I have run Milodon bronze gears the most. only 1 mp bronze drive gear. I can tell you that when all is set up the Milodon gives no problems. They make a few different ones for all pump designs. I would agree on a lighter weight oil as well, or as stanton suggested, you may even consider a stock pump. It sounds like your engine is built on the close side of tolerances. You did say you were street driving and it's not a race car. It may even run cooler. Also, set your cam run out to as little as you can get. Your tare downs won't be as dramatic. You have a great looking engine.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399705
03/12/13 05:34 AM
03/12/13 05:34 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Does anyone know the part# for the Milodon gear with a factory length oil pump drive?
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399706
03/12/13 06:27 AM
03/12/13 06:27 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Wedge and Hemi using stock-style pan and tube pick-up. Also used with Milodon Oil Systems #21000, #21010, #21100, #21110 and systems using a Keith Black pump.
Bronze Gear #21525
Re: Bronze dizzy gear faliure in Hemi need help! [Re: nz383man] #1399707
03/25/13 05:00 AM
03/25/13 05:00 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Update: Std volume oil pump and Milodon gear and drive installed, oil presure has dropped from 65 psi+ at idle to 45 psi and at revs from 90 psi down to 60 psi.Will keep a close eye on the new gear!
Thanks for all the imput Tim
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399708
03/25/13 06:23 PM
03/25/13 06:23 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Tim
.015" end play on the cam is a bit too much. I would drop that down to about .005-.006". Two things force a stock flat tappet cam backwards on a big block Chrysler. One the position of the distributor drive and the helix on the cam/distributor drive gear and the other is the taper on the lobes. Roller cams are ground flat so the only thing driving it back is the first point.
However, acceleration/deceleration will cause the cam to walk. Also, if your lifter bores are not straight or out of alignment, this could cause the cam to walk forward.
I would side on the opinion that thicker oil can wear out the gear prematurely. It takes more force to spin the pump. Also, if there are any burrs or imperfections on the cam drive gear it will wear the gear early. Usually the first gear wears out faster until the cam gear takes a "set".
Re: Bronze dizzy gear faliure in Hemi need help! [Re: torkrules] #1399709
03/25/13 06:46 PM
03/25/13 06:46 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
It doesn't matter whether the engine is accelerating or decelerating, the crank is still turning in the same direction. The crank is still driving the cam in the same direction, and the cam is still driving the oil pump in the same direction. The cam is being forced back towards the back of the block by the resistance of the oil pump drive.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mick70RR] #1399710
03/25/13 07:14 PM
03/25/13 07:14 PM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
my meaning is the changes in velocity of the cam that occurs when the engine changes speed(rpm). Yes, if you want to be specific, the resistance in the oil pump contributes greatly to this action. Same thing happens with the rear axle gears when you get on an off the throttle.
