Bronze dizzy gear faliure in Hemi need help! #1399673
03/09/13 05:24 PM
03/09/13 05:24 PM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Hi, bronze dizzy gear has falied in my Hemi after 2000 road miles, what is the best brand gear to buy to replace it. Also a friend pointed out I may have to much oil presure which is componding the wear problem. The motor has 65psi hot idle and 90psi when the revs are up, it has a meling H/V pump.
Does anyone offer a softer bypass spring for these pumps, would this help?
Thanks Tim
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399674
03/09/13 05:29 PM
03/09/13 05:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thanks Tim
Lowering the oil PSI certainly wouldn't hurt. Maybe try a thinner oil? I went from 15W40 to 10W30 and my idle picked up 200RPM for an idea of how much load is on that gear. I just recently tore mine down for inspection and with 2500 miles on it the bronze gear was perfect(20psi idle 65psi on the road at 3000rpm).
68 Barracuda Formula S 340
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Bad340fish] #1399675
03/09/13 05:57 PM
03/09/13 05:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Swap out that HV pump for a standard one, pressure is a function of volume.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399676
03/09/13 11:55 PM
03/09/13 11:55 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Don't run too thick of oil, cut the relief spring down a bit, and be sure to run the collars on the distributor shaft. It helps keep the wear pattern more consistent.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: jbc426] #1399677
03/10/13 12:06 AM
03/10/13 12:06 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The problem with just cutting the spring is that the pump will still have to move the same volume - but push it through the bypass. So power is wasted driving the pump and the oil is heated needlessly going though the bypass - not to mention the strain on that drive gear! With the kind of pressure the OP has he does not need the hv pump.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Stanton] #1399678
03/10/13 12:53 AM
03/10/13 12:53 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
Thanks for the replies,current oil is ULX 20w50 what would you recomend and is there any preferances for bronze gear manufactures?
I will also drop back to a std pump. Tim
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399679
03/10/13 03:59 AM
03/10/13 03:59 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
It's the thick oil you're running. Try a max of 10-30wt. You may need the extra volume with the thinner oil.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399680
03/10/13 04:00 AM
03/10/13 04:00 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
When mine wears out, I'm going to have my next bronze gear cryogenically treated.
Also, I switched to the new Milodon pump body and am using the stock cover on it. It reportedly takes significantly less power to drive it due to a more pointed shape of the gerator lobes.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399681
03/10/13 03:43 PM
03/10/13 03:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I never run anything thicker than 10w30 and I run the same HV pump w/70 psi hot and down to 30-40 at cruise..........stock springs no mods.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399682
03/10/13 04:29 PM
03/10/13 04:29 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Although your posted oil pressure is a bit high, Im going against the grain here and saying its not the oil.....
Ive run 20W 50VR1 in my own driver Challenger and the gear lasted years, I inspected it regularly, but there wasnt any appreciable wear. How many miles?? WAY more than 2000 and 10+ years. And I live in an area where I did start it on some pretty cold days.
You live in Australia, so I assume you arent staring the car in zero degree temps..
I notice you are running a chrome sheetmetal timing cover. How are you controlling cam end play. If you think that cover wont deflect, you are wrong. Ill bet that cam is walking like crazy if you dont have something in front of that cover to limit endplay..
Edit: My apologies, I thought the pic another memnber posted was the OP's. Anyway, how are you(OP) controlling end play? What type of timing cover are you running?
Look into that.
MB
Re: Bronze dizzy gear faliure in Hemi need help! [Re: HPMike] #1399683
03/10/13 05:18 PM
03/10/13 05:18 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My first thought was cam walk, also loose bushing, or bushing not seated all the way down, or shaft to long for the pump.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399684
03/10/13 05:29 PM
03/10/13 05:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
With that kind of pressure I'd scrap the HV pump and go to a standard volume. It's obvious that the motor can't handle the volume being pumped and the excess volume is causing the high pressure.
A softer spring probably won't help because the relief valve, even wide open, can only handle so much volume.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: John_Kunkel] #1399685
03/10/13 07:21 PM
03/10/13 07:21 PM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
To reply to some of the answers.
The bush in the block is now worn but I beleive this is a result of debris from the bronze gear getting in between the drive and the bush as the drive is marked up in that area.
I have one of those Diamond roller thrusts on the front of the cam and a factory timming cover.
The motor is a 557ci using a World block.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399686
03/10/13 07:29 PM
03/10/13 07:29 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
factory cover and roller do not mix without support
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399687
03/10/13 09:09 PM
03/10/13 09:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Bronze gear against bronze bushing = wear. Same reason you don't use a steel gear with a steel roller cam ... similar metals !!
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399688
03/10/13 10:40 PM
03/10/13 10:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Yep...that cam is deflecting that cover. If you dont believe it, install the cam and cover just take a long screwdriver and carefully see how easy and how far that cam will walk..
Here is what I do...
Install the cam without the cover and put some paint on the nose of the button. Install the water pump housing and push the cam forward until it contacts the back of the housing(paint will leave a mark).
Build up some weld(Ill start with a half dollar in diameter) and about 3/16" thick weld.
Install the cover with gasket and then the housing also with the gaskets. Obviously dont glue anything in place yet-this is the mock up phase. Usually in the beginning, you wont be able to get the housing on(weld too thick). Then just keep grinding that weld "button" down until you have the desired end play.
Takes a little time, but makes for a better stop.Or you can use one of Andy F's covers.>>I think they have a provision for obtaining end play.
MB
Re: Bronze dizzy gear faliure in Hemi need help! [Re: HPMike] #1399689
03/10/13 11:53 PM
03/10/13 11:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You want one of these cast covers - available from Promax in Indianapolis for $100. They fit under a stock pump and are thick enough to drill and tap for a plug so you can accurately measure cam endplay.
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Stanton] #1399690
03/11/13 04:03 AM
03/11/13 04:03 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
The bush in the block is not worn on the top where the bronze drive runs on it is worn inside where the oil pump drive runs, that is why I suspect dedris from the bronze drive failure got between the drive and the bush. The drive is marked up where it runs in the bush.
Correct me if I am wrong but dosnt the turning of the dizzy/oil pump drive force the cam to the back of the block, I thought this is what the torrington on the back of the timmig gear set was for?
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Teamx] #1399691
03/11/13 04:21 AM
03/11/13 04:21 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The bushing is worn inside from the cam walking forward and trying to put pressure on the drive shaft. The roller button mounts on the front and is stopped by the timing cover. A factory cover will flex and allow the cam to move forward, even with the roller button
Re: Bronze dizzy gear faliure in Hemi need help! [Re: Mopar-Al] #1399692
03/11/13 06:56 AM
03/11/13 06:56 AM
Australia
Teamx Offline OP
Teamx  Offline OP
Australia
The end play is set at .015thou. I understand the timming cover may flex a little if the button runs against it.
Tim
