What shocks to put on front lowered d150? #1399499
03/09/13 01:04 PM
03/09/13 01:04 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
I lowered a D150 2 inches in the front and 6 inches in the back. by doin the rear end flip and cutting the springs in the front. Now all I need is shocks on the front. I was wondering which to get or if anybody has had to get these yet? I can only find shocks for stock height d150's Any help?
Re: What shocks to put on front lowered d150? [Re: 1967-418] #1399500
03/09/13 01:13 PM
03/09/13 01:13 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Do a search. Its been asked before. I used stock shocks when I lowered the front
Re: What shocks to put on front lowered d150? [Re: 76dodgeboy] #1399501
03/09/13 05:31 PM
03/09/13 05:31 PM
anacortes,wa
78asprin Offline
78asprin  Offline
anacortes,wa
Contact the guy at mid america customs, I used his lowering kit and the shocks have never bottomed out
Re: What shocks to put on front lowered d150? [Re: 78asprin] #1399502
03/09/13 07:38 PM
03/09/13 07:38 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you use Lca's without the pocket use stock length
If you use LCA's with a pocket you use shocks for a 4000# front axle they are longer to compensate for the pocket
6" rear 2" front Gasser Look?
Re: What shocks to put on front lowered d150? [Re: BulletBob] #1399503
03/09/13 10:57 PM
03/09/13 10:57 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
My bad I meant 6 in the rear and 4 in the front. Here a pic.
Re: What shocks to put on front lowered d150? [Re: 78asprin] #1399504
03/09/13 11:16 PM
03/09/13 11:16 PM
illinois
1967-418 Offline OP
1967-418  Offline OP
illinois
Also, I cant seem to find a website or phone number anywhere for mid america customs. You have a URL or phone number for them
Re: What shocks to put on front lowered d150? [Re: 1967-418] #1399505
03/10/13 12:13 AM
03/10/13 12:13 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They are a diff company now. I think its saved on the computer. I'll check in the morning. If you have a good parts store guy he can find what you need
Re: What shocks to put on front lowered d150? [Re: 76dodgeboy] #1399506
03/10/13 12:31 PM
03/10/13 12:31 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
If I remember correctly.....pontiac fireo ones worked...but i also remember buying a small truck set &swapped out the lower mount bar from the old shock.
I wish i could remem er which small truck.
Re: What shocks to put on front lowered d150? [Re: 1967-418] #1399507
03/11/13 10:30 AM
03/11/13 10:30 AM
Dearborn, Michigan
jstollfu Offline
jstollfu  Offline
Dearborn, Michigan
Don't call Mid America Customs for anything.. In fact you can't call them anymore because that guy has finally taken down his web site. The stuff that came in his kits were junk. The shocks were just stock length shocks. I had to replace them in less then a year.
Use stock front shocks they will work fine. I used KYB shocks on mine I got from Rock Auto. You don't need a special (Shorter) shock. Although someone on here might chime in that you do. You don't.
Re: What shocks to put on front lowered d150? [Re: jstollfu] #1399508
03/11/13 01:20 PM
03/11/13 01:20 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
http://3rdstrikeperformance.com/index.php?main_page=index&cPath=8140_23_71_321_2283
My hub was 13" for the fender well lip with cut coils. I used stock shocks
