Moroso SB Deep pan - ?'s #139949
10/22/08 09:18 AM
10/22/08 09:18 AM
Missouri
convertriple Offline OP
super gas
super gas
Missouri
I put 8 quarts in my 8 quart Moroso smallblock oil pan on a fresh motor, but the stock (5 quart) dipstick shows the level a couple of quarts low yet.
Is this normaal? Is there a different dipstick I should be using?
Re: Moroso SB Deep pan - ?'s [Re: convertriple] #139950
10/22/08 09:57 AM
10/22/08 09:57 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Full level stays constant on the dipstick. It is the lower level that changes. did you also add the extended pick up tube?? If so you 'should' be fine, but personally I would fill to the add line.
Re: Moroso SB Deep pan - ?'s [Re: MoparforLife] #139951
10/22/08 10:02 AM
10/22/08 10:02 AM
Missouri
super gas
super gas
Missouri
Yep, got the deep pickup tube (even have an extra ), it will take at least 10 quarts to fill it if I go to the "full" line!
Re: Moroso SB Deep pan - ?'s [Re: convertriple] #139952
10/22/08 11:47 AM
10/22/08 11:47 AM
Locomotion Offline
Locomotion  Offline
You don't need to fill it all the way. While extra capacity is helpful, a deep pan allows more oil than OEM, but keeps it further away from the crank and reduces windage, especially when its sloshing around. The deeper sump and baffles keep more oil around the pick-up.
I never run more than 5 qts in the race car.
Re: Moroso SB Deep pan - ?'s [Re: Locomotion] #139953
10/22/08 03:40 PM
10/22/08 03:40 PM
Missouri
super gas
super gas
Missouri
I hear ya, I was only going to put 6 quarts in for break-in, but it wasn't even on the stick! Thats why I added the other two, but it's still about two short of hitting the line.
I may get a longer dipstick out of a truck, see if that works.
