Hemi carburator? #1399457
03/09/13 11:01 AM
03/09/13 11:01 AM
cudanut Offline OP
cudanut  Offline OP
I have a hemi carb number 4139 s dated a6 also have one dated e6. The first dated a6 has 2 holes on each corner to mount it to the manifold. The other only has 2 holes on two corners to mount it. Was there a change or did someone just drill the other 2 holes. I have other hemi carbs they all are the same as the e6 carb with two holes on two corners.
Re: Hemi carburator? [Re: cudanut] #1399458
03/09/13 11:24 AM
03/09/13 11:24 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The extra holes were added. All 66-71 Street Hemi carbs had the same mounting hole locations.
Re: Hemi carburator? [Re: ScottSmith_Harms] #1399459
03/09/13 07:11 PM
03/09/13 07:11 PM
cudanut Offline OP
cudanut  Offline OP
Thanks i didn't know if it was an early thing because some of the early afbs do have 2 holes on each corner for chevy . The holes do look like factory but i guess not.
