Any guesses on E.T. loss? #1399206
03/08/13 08:22 PM
03/08/13 08:22 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
At the last race in October I broke the 9 in. center section in my D-50. That night I ran my quickest E.T. and 60 ft. so far. I run 1/8 mile and it was a 1.34 60 ft. ,6.34 @ 108 mph. I had another center section with a mini spool and 3.50 gears so I put them in for now.
How much do you think it will slow it down. I had 5.14 gears last year.
It is a Indy 360-2 headed pump gas 394 c.i. with mufflers and Drag radials. It weights 2950 lbs with me in it. I will be going to T&T tomorrow.I will let you now what it runs.
Glenn....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Any guesses on E.T. loss? [Re: D-50] #1399207
03/08/13 09:47 PM
03/08/13 09:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As a guess you will drop to a 1.7 60'and a 6.90
Re: Any guesses on E.T. loss? [Re: MR_P_BODY] #1399208
03/08/13 09:56 PM
03/08/13 09:56 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
How did it feel out on the street ?
That motor is all about low end TQ I think it had to much gear before.
3.50 is not the answer but may not hurt as bad as you would think.
I would like to see 4.5ish gear in it.
Did you put the 1050 on?
Re: Any guesses on E.T. loss? [Re: MR_P_BODY] #1399209
03/08/13 09:56 PM
03/08/13 09:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i'll guess and say no where near that much maybe .2 or close if that much. I had a 69RR years ago and went from a 391 all the way up to a 513 and it didn't change hardly anything
Re: Any guesses on E.T. loss? [Re: D-50] #1399210
03/08/13 10:02 PM
03/08/13 10:02 PM
Washington
skrews Offline
skrews  Offline
Washington
1.42 60" 6.45 1/8 @ 107-108
Re: Any guesses on E.T. loss? [Re: D-50] #1399211
03/08/13 10:10 PM
03/08/13 10:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what was the gear raito before.. and what is the stroke. but I would say you will lose less than a tenth you might add 2or3 degrees of timing
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Any guesses on E.T. loss? [Re: W5DART66] #1399212
03/08/13 10:11 PM
03/08/13 10:11 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I have not put the 1050 on it yet. I have not bought a fuel pump yet. Plus I do not want to change more than one thing at a time. I wanted to see what it runs with the gear change. When I had the 360/380 HP crate motor in it I did the same gear change. It had run a best of 7.46 with the 5.14 and ran a 7.60 with the 3.50 gears. I had a 1.53 60ft. with the 5.14's and 1.67 with the 3.50 gears. So maybe it will run some 6.50's in 2nd gear.
Re: Any guesses on E.T. loss? [Re: D-50] #1399213
03/08/13 10:20 PM
03/08/13 10:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if you had other issues maybe the lower rpm will
help but if all was good then I'll stick to my guess
Re: Any guesses on E.T. loss? [Re: D-50] #1399214
03/08/13 10:35 PM
03/08/13 10:35 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
STROKE ?
Re: Any guesses on E.T. loss? [Re: WHITEDART] #1399215
03/08/13 10:36 PM
03/08/13 10:36 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
3.79
Re: Any guesses on E.T. loss? [Re: D-50] #1399216
03/08/13 10:54 PM
03/08/13 10:54 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I think you will go faster with a 4.30 or 4.56 than you did with 5.13. with my car I have tried 4.10. 4.56.and 5.00 and seen very little change in the 1/8 mile but 3.50 is pretty flat. I still thank about a tenth.
Re: Any guesses on E.T. loss? [Re: D-50] #1399217
03/08/13 11:33 PM
03/08/13 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One other thing... whats your conv stall, if its
high enough it will help you out some to help cover
up the gear... to a point
Re: Any guesses on E.T. loss? [Re: MR_P_BODY] #1399218
03/08/13 11:49 PM
03/08/13 11:49 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
8 in. PTC flashes 5200 - 5500 it seems to be looser with the higher gears. I was shifting at 6800 and crossing the finish line about 6800 with the 5.14's. I am not sure where to shift at tomorrow, I am sure I will go through in 2nd gear. I have another center section that is borrowed that has 4.56 gear in it. I might try in a couple of weeks. I am afraid I will break the cap in it too.
Re: Any guesses on E.T. loss? [Re: D-50] #1399219
03/08/13 11:54 PM
03/08/13 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is your 8 3/4 back braced.. also if you put load bolts
in the back, that really helps the stock caps
Re: Any guesses on E.T. loss? [Re: MR_P_BODY] #1399220
03/08/13 11:56 PM
03/08/13 11:56 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Sorry it has a 9in.
Re: Any guesses on E.T. loss? [Re: D-50] #1399221
03/09/13 12:02 AM
03/09/13 12:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry it has a 9in.
Yeah... sorry I forgot... is it still back braced
Re: Any guesses on E.T. loss? [Re: MR_P_BODY] #1399222
03/09/13 03:08 PM
03/09/13 03:08 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
3-speed 2/10ths, powerglide 4/10ths.
Re: Any guesses on E.T. loss? [Re: cgall] #1399223
03/09/13 03:34 PM
03/09/13 03:34 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
The 9in. is not back braced and it has a 727 in it. I am leaving now to go and see what it will do.
Re: Any guesses on E.T. loss? [Re: D-50] #1399224
03/09/13 09:01 PM
03/09/13 09:01 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Just got back from T&T and the 3.50 gears did not slow it down that much. The best pass today was 1.42 60ft. 6.46 @ 107.60 crossing the finish line in 2nd gear.
Re: Any guesses on E.T. loss? [Re: D-50] #1399225
03/09/13 09:16 PM
03/09/13 09:16 PM
gregsdart Offline
gregsdart  Offline
Makes sense to me. You have more than enough stall, too much gear before, and the 2.45 low. Had it been with a glide and a tight converter, you would still be waiting to cross the finish line
