Re: roll cage installation
[Re: maxie]
#1399012
03/08/13 05:12 PM
03/08/13 05:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Will you be tiging or miging it.... I normally have each leg of the weld 1 material thickness when I tig but with mig its larger with a nice radius at the center... with either type dont under cut
[Re: MR_P_BODY]
#1399013
03/08/13 07:44 PM
03/08/13 07:44 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I don't do much of any cages with mild steel. And don't do much wire welding on tubing anymore. But, something I would recommend if Mig welding it would be to leave a .065 gap between the tubes I was welding. This way you get more weld in the joint and not just a fat bead on top.
If you get someone to tig it you will want the joints as tight as possible as if you were going to super glue it together LOL.
[Re: maxie]
#1399015
03/09/13 02:42 PM
03/09/13 02:42 PM
Leon441
Lynchburg, VA
I would worry more about good welds than the roll of dimes. I have seen some very attractive welds broken.
I'm sure you can do a good job. Like others said at least the thickness of the tube no more than 1.5 times the tube thickness if you can help it.
Leon
[Re: Hemi Joe]
#1399016
03/09/13 06:49 PM
03/09/13 06:49 PM
Posts: 221 Missouri
Challenger
Missouri
Bob George Racing installed a cage in my 65 and did a great job!!! I will always be thankful to Bob for the installation, due to the fact that it was an emergency situation in which NHRA failed my exhisting cage during a chassis certification. The regional tech measured my cage on one of corners, where the steel stretches and he told us that the Jegster tubing was not thick enough. Thanks to Bob we were able to make our next race the following week, we will always be greatful!!!!! HEMI JOE -- Endanger Species Racing
Correct me if Im wrong,but I was under the impression that the NHRA techs do not measure corners where the steel stretched only on straights. Could this be a area where it depends on what tech you get?
[Re: Challenger]
#1399017
03/09/13 07:03 PM
03/09/13 07:03 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Usually 6" from any radius or weld connection.
[Re: maxie]
#1399018
03/10/13 03:03 AM
03/10/13 03:03 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
We are in the process of putting the cage in the demon. It is a 8 point kit, nonchromoly.
My question is how large do the beads of weld have to be?
I emailed division 3, but havent heard anything yet.
Here's a sample weld on my Coronet. 8 point welded in, not chro-mo. Never had any issues with tech at 'Da Grove here in WI.
