1969 Road Runner no broadcast sheet but...... #1398679
03/07/13 04:09 PM
03/07/13 04:09 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Current owner purchased car from original owner who ordered it new.
Broad cast sheet missing
Fender tag here but rusty
Current owner has paper work that was filled out at dealership when ordered new, showing options. I know that Broadcast Sheets and
Fender tags create controversy,could I have B/S and F/T made with or from this paperwork? This is a #s matching(eng/trans) Factory A/C
RR and don't want to cast doubt on the car by getting these items duplicated.Thoughts?
Re: 1969 Road Runner no broadcast sheet but...... [Re: 68GTS383] #1398680
03/07/13 06:24 PM
03/07/13 06:24 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
If the car was built according to the dealership order, and you have that info and the original fender tag, I don't see a problem. For any serious judging, you could display copies of your documentation. And definitely make copies and store the originals safely with the car's file.
Oh, and it's "doubts", since you seem to have asked. Advance apologies to anyone who gets bent out of shape that I'm advising the correct spelling.
Re: 1969 Road Runner no broadcast sheet but...... [Re: 68GTS383] #1398681
03/07/13 06:37 PM
03/07/13 06:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
As long as you have the original fendertag and it is legible for ALL info posted on it then there will never be any question to its validity and will not cast any shadows on the car.
The Broadcast sheet will NEVER be legit so save your money you have the order form from the original dealer , that's as good , this case better than a FAKE broadcast sheet .
Re: 1969 Road Runner no broadcast sheet but...... [Re: JohnRR] #1398682
03/07/13 07:47 PM
03/07/13 07:47 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
reproduce the FT from the original if you wish, and keep the original FT and paperwork in a safe place. Don't bother with the broadcast sheet.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1969 Road Runner no broadcast sheet but...... [Re: 68GTS383] #1398683
03/07/13 08:01 PM
03/07/13 08:01 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
....could I have B/S and F/T made with or from this paperwork?
Sure. Many have. And either will cast doubts on the legitimacy of the car.
I agree with John and Dave. Better none and let the car stand on it's own rather than faking BS or fender tags.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1969 Road Runner no broadcast sheet but...... [Re: 69CoronetRT] #1398684
03/07/13 08:51 PM
03/07/13 08:51 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Thoughts on laminating original paper work?
Re: 1969 Road Runner no broadcast sheet but...... [Re: 68GTS383] #1398685
03/07/13 09:38 PM
03/07/13 09:38 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Done properly, it can be a good thing. But consider...would you have wanted the paperwrok already laminated? Does the next owner?
Seeking:
Re: 1969 Road Runner no broadcast sheet but...... [Re: 69CoronetRT] #1398686
03/07/13 10:21 PM
03/07/13 10:21 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Laminating is a good way to preserve the sheet but here is a little known fact that you should be aware of BEFORE you do it. Many sheets have grease pencil writing on them that sometimes covers codes and makes them hard or impossible to read. The grease pencils had graphite in it which is the same thing used in a regular old pencil. After 40 years the grease is long gone but the graphite remains. You can usually use just a regular pencil eraser to remove it and likely read the code under it. If it does not work your have lost nothing. I have had great results with it on old sheets in the past.
