dana 60 fluid capacity #1398664
03/07/13 03:14 PM
03/07/13 03:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
read on head a few weeks ago some here were running 1qt fluid in dana 60 for race application. what would you recommend for lite street and lite strip?
Re: dana 60 fluid capacity [Re: mopar dave] #1398665
03/07/13 05:34 PM
03/07/13 05:34 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
To the bottom side of the fill hole.
Mopar Performance
Re: dana 60 fluid capacity [Re: moparniac] #1398666
03/07/13 05:38 PM
03/07/13 05:38 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
2 qts
Re: dana 60 fluid capacity [Re: sixpackgut] #1398667
03/07/13 05:44 PM
03/07/13 05:44 PM
an8sec70cuda Offline
2 qts
No more than 2 quarts. Ray and I have talked about this before.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: dana 60 fluid capacity [Re: an8sec70cuda] #1398668
03/07/13 09:56 PM
03/07/13 09:56 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks. Gonna put the new moser pan on tomorrow and 2qts max gear.
Re: dana 60 fluid capacity [Re: mopar dave] #1398669
03/07/13 10:18 PM
03/07/13 10:18 PM
IN
Dartman928 Offline
Dartman928  Offline
IN
Would this be the same for an 8 3/4?
Re: dana 60 fluid capacity [Re: Dartman928] #1398670
03/08/13 12:18 AM
03/08/13 12:18 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
2.5 qts. in ours
Re: dana 60 fluid capacity [Re: an8sec70cuda] #1398671
03/08/13 12:39 AM
03/08/13 12:39 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
2 qts
I have plenty of my 3rd qt left is there .05 or something going with 2 qts dead on or something
Mopar Performance
Re: dana 60 fluid capacity [Re: moparniac] #1398672
03/08/13 01:13 AM
03/08/13 01:13 AM
Mt Morris Michigan
Mt Morris Michigan
no idea,but I can tell you I drained out 3.5qts and it was filled up to the fill hole. 2qts going back in.
Re: dana 60 fluid capacity [Re: moparniac] #1398673
03/08/13 01:27 AM
03/08/13 01:27 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
2 qts
any more than that the forearms start hurting
Re: dana 60 fluid capacity [Re: mopar dave] #1398674
03/08/13 01:38 AM
03/08/13 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it a street car.... if so fill it properly... it
draws off heat... drag car run it short
Re: dana 60 fluid capacity [Re: MR_P_BODY] #1398675
03/08/13 12:33 PM
03/08/13 12:33 PM
What is properly?
Re: dana 60 fluid capacity [Re: ] #1398676
03/08/13 01:03 PM
03/08/13 01:03 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
What is properly?
Bottom of fill plug.
Re: dana 60 fluid capacity [Re: Dodgeguy101] #1398677
03/08/13 02:43 PM
03/08/13 02:43 PM
Mt Morris Michigan
Mt Morris Michigan
installed pan, filled with 2.5qts amsoil max gear. done. to the fill hole would take about 4qts or maybe more.
Re: dana 60 fluid capacity [Re: mopar dave] #1398678
03/08/13 03:05 PM
03/08/13 03:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
It will take more than what the FSM is your running a spool instead of a posi unit Mopar engineers use to recommend, in the old drag seminars they put on for the public, using one quart of gear oil in both the Dana 60 and the 8 3/4 for drag racing, no matter if a posi or spool was used
