Sikkens Mixing Formula Y2 Yellow #1398649
03/07/13 01:57 PM
03/07/13 01:57 PM
California
sixpaktoogo Offline OP
California
Does anyone have the Sikkens mixing formula for 1969 Y2 Sunfire Yellow? I need the gallon formula to mix.
Thanks, Dan
Re: Sikkens Mixing Formula Y2 Yellow [Re: sixpaktoogo] #1398650
03/07/13 02:40 PM
03/07/13 02:40 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Base/clear or single stage?
If you have a sample, Sikkens has a "color map" that you can match from. Color map is a book of thousands of chips that you can pull a formula from. I have used it to get a match for colors where the formula is unknown. The paint jobber, or a good shop will have this tool. A spray out panel can be done on the colors selected.
