Re: No Ballast Resistor with Accel Super Coil??
[Re: justintyme]
#1398541
03/07/13 02:08 PM
03/07/13 02:08 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Its been probally 30 years since I ran one but IIRC it had a resistor.Accel should have it on their site.Rocky
Chrysler Firepower
[Re: therocks]
#1398542
03/07/13 03:04 PM
03/07/13 03:04 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I still run the old accel super coil on my 63 with the MP orange box. I believe my ballast is a .75 as its been on the cars for years. Runs in the 10's with it and no ign problems at all. If I get out to the garage today I will double check the ohms. I remember years ago when you bought the super coil it came with a .25 ohm ballast that you were supposed to add in series with the stock ballast. But when I put this together years ago I just used the one ballast which I believe is .75 ohms. Ron You can see part of the super coil past the dist as I mounted it on the fenderwell. Ron
[Re: Dunnuck Racing]
#1398548
03/08/13 12:40 AM
03/08/13 12:40 AM
Posts: 5,330 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
When I first purchased my Duster a few years ago, it had an Accel big yellow coil on the firewall with a ballast resistor, and factory electronic ignition. I simply changed out the yellow coil for a factory black unit...the car ran fine with the Accel, just wanted a cleaner look under the hood. Use a resistor.
Plymouth Makes It!
