Re: No floor heat
[Re: Lew]
#1398520
03/08/13 09:57 AM
03/08/13 09:57 AM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
04 1500 5.7 ram, heat will not transfer to floor, same with 98 dakota,must be a typical prob, any ideas? thanks
At this point im guessing im the only one in the world with this problem?
Re: No floor heat
[Re: ZIPPY]
#1398525
03/08/13 03:30 PM
03/08/13 03:30 PM
Challenger 1
Cincinnati, Ohio
Lew,
Here is the best resource I know of for that, it will teach you how to fix it and will show you everything you need. http://www.heatertreater.net/magento/index.php/dodge/ram/02-08/dodge-ram-02-08.html
Rich
Wooo, learn something everyday. Thanks I have replaced the motors on International trucks and GM pickups, never seen or heard of a broken door. But I have not worked on dodge trucks since 93 when I got rid of our last dodge. Sadly or luckly I have not had one since.
Dang there's seems a lot of things to go wrong on these late model dodges??
Re: No floor heat
[Re: Challenger 1]
#1398526
03/08/13 05:23 PM
03/08/13 05:23 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Glad to help you too Gary. They aren't perfect...a guy could do much worse though, and I think they're a darn good vehicle in spite of knowing this stuff. The wiring and grounds for stuff like fuel pumps is probably the most mysterious and nonsensical...follow the wiring coming out of the fuel pump someday, see if you can guess where the ground is for the pump, and you will see what I mean The wiring is my least favorite part of those trucks to work on...
Rich H.
Esse Quam Videri
