Flow Chart Numbers on Exhaust manifolds #1398361
03/07/13 01:06 AM
03/07/13 01:06 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
I've been listening for years on how the driver side manifold on the big block A bodies was restrictive causing a major effect on HP. Well, my buddy who owns a flowbench decided to put the argument to rest with some old fashion testing. See the attached results.
Looks like the A body driver side manifold fared pretty well
DS AQ Body 383 manifold - @ .500" of lift it flowed 157.4 CFM
PS A Body 383 manifold - @.500" of lift flowed 164.2 CFM
C Body DS magnum manifold - @ .500" of lift flowed 161.2 CFM
The second chart depicts flow numbers from the most restrictive part of each manifold
Sorry about the pics. Couldn't figure how to attach a PDF file
CHART 1
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398362
03/07/13 01:35 AM
03/07/13 01:35 AM
Mesa, Arizona
Mesa, Arizona
CHART 1 Data
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398363
03/07/13 01:36 AM
03/07/13 01:36 AM
Mesa, Arizona
Mesa, Arizona
CHART 2
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398364
03/07/13 01:36 AM
03/07/13 01:36 AM
Mesa, Arizona
Mesa, Arizona
CHART 2 Data
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398365
03/07/13 02:07 AM
03/07/13 02:07 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It would be interesting to get the data on a B-body HP manifold as that is supposed to flow better.
Re: Flow Chart Numbers on Exhaust manifolds [Re: Jim_Lusk] #1398366
03/07/13 02:22 AM
03/07/13 02:22 AM
Mesa, Arizona
Mesa, Arizona
I have a B body manifold but I need to get it cleaned and shot blasted. The closest thing I had at the time was a C body magnum manifold. The passenger side A manifold most likely flows the same as the B body
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398367
03/07/13 01:57 PM
03/07/13 01:57 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
How was this tested?
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398368
03/07/13 02:16 PM
03/07/13 02:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The A body PS side manifold is a little different in the rise just behind the # 6 outlet to clear the inner fender I assume , not sure if it is a restriction. If I ever get around to getting my 383 on the dyno I'm going to run the A body and B body manifolds on it as a comparison.
Re: Flow Chart Numbers on Exhaust manifolds [Re: JohnRR] #1398369
03/07/13 04:18 PM
03/07/13 04:18 PM
From the August 1967 issue of "Hi-Performance Cars" magazine:
When we first learned that the [67 383 Barracuda] engine was only rated at 280 hp instead of 325, we immediately jumped to conclusions and pointed our fingers at the factory for cheating on the engine's rating so that the car would be shoehorned into a more desirable NHRA stock class. Plymouth's explanation was that they lost 40 to 50 hp when they had to redesign the headers to clear the chassis and shock towers on the Barracuda. This is actually nonsense as the headers do not appear to be any less restrictive than the ones on the middleweight model 383's and they would have to route them in a spiral pattern up the steering column to lose that much horsepower!
Re: Flow Chart Numbers on Exhaust manifolds #1398370
03/07/13 06:51 PM
03/07/13 06:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't know , that looks conjecture to me. 67 is a one year manifold on the drivers side , they changed the part that goes around the column for 68/69 and upped the rating , but I think 68 is only 300HP , 69 is 330hp. I don't know which cam was used in 68 but the 69 is the same engine that is in the Road Runner and Superbee rated at 335hp, same cam,a same carb number. The 383 in the 69 A bodies only differences are the exhaust manifolds and it has a dual point instead of the RR/SB engine having a single point distributor.
Re: Flow Chart Numbers on Exhaust manifolds [Re: JohnRR] #1398371
03/07/13 07:18 PM
03/07/13 07:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't doubt that Chrysler may have played with the ratings to fit the car into an NHRA class; oftentimes ratings were published at a lower RPM than what may have provided bigger #s.
That said, I recall a set of A-body 440 headers (race Hookers) on a Stock Eliminator '69 Cuda that gave almost 40 HP less on the dyno than a set that wouldn't fit that chassis.
Another consideration is how that manifold measurement relates to what the head is trying to push through it; for example, if each port is trying to push 200CFM, what will the manifold flow? Seems like you'd have to rig it on a flow bench so that firing order was duplicated & factored in.
Re: Flow Chart Numbers on Exhaust manifolds [Re: topside] #1398372
03/07/13 07:24 PM
03/07/13 07:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I just remembered also the A body has a cork for an 3xhaust system , 2.25 headpipes and 2" tailpipes .
I guess they are right baout the lower HP rating , what class would the 67 BB dart have run . The Magnum engine wasn't out yet so 33oHP was the top engine in 67 , I assumed the dart got the 300 hp engine as a base ?
Re: Flow Chart Numbers on Exhaust manifolds [Re: JohnRR] #1398373
03/07/13 07:36 PM
03/07/13 07:36 PM
1967 B body 383's only had 2.25 exhaust pipes, and I think the tailpipes were only 1 7/8" (but I could be wrong on that, might have been 2").
Plus the 67 B body 383's didn't have hi-po exhaust manifolds; they had the ones below, under my 69 A body manifolds. No way the A body manifolds cost 45 hp.
One more thing: Because the 67 driver's side manifold is different than the 68-9, and the 67's hp rating was the lowest, everyone assumes the 67 driver's side manifold is more restrictive than the 68-9. I've seen both, and I don't see the 67 being more restrictive. The 68 A body 383's got better heads, intake manifold and carb, and the 69 got a better cam; that's where the increased hp ratings in 68-9 came from. IMHO.
OK, still one more thing: A 2-barrel 383 with a dinky 252 degree cam and single exhaust was rated at 305 hp in 1964. There's no way it really had more hp than a 67 A body 383 4-barrel with dual exhausts. I don't know why Chrysler dropped the hp rating for A body 383's compared to B body 383's, but I think it's pretty obvious they did.
Re: Flow Chart Numbers on Exhaust manifolds #1398374
03/07/13 07:49 PM
03/07/13 07:49 PM
Okay, one more thing. Most road tests of the 67 383 Barracuda have it running 15.2 to 15.4 in the quarter mile. Hi-Performance Cars magazine got theirs into the high 14's. Super Stock and Drag Illustrated (April 1967) got the bright idea to shift the automatic trans manually and got theirs down to 14.53, which was only two tenths slower than a 67 Coronet R/T they had tested three months earlier.
R/T's five best runs:
14.35 @99.00
14.37 @100.11
14.46 @99.88
14.49 @100.11
14.52 @99.88
First run for the 383 Barracuda, left in drive: 15.37 @92.59
Shifting the torqueflite manually:
14.91
14.80
14.79
14.68
14.56
14.53
Trap speed was 97.
The R/T ran best in Drive. The 383 Barracuda ran much better shifting manually.
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398375
03/07/13 11:14 PM
03/07/13 11:14 PM
Mesa, Arizona
Mesa, Arizona
If you look at the numbers you'll see there's little difference between the manifolds that would suggest a significant HP difference relating to exhaust flow. With that said I would lean more toward the fact that manipulation of information from Ma Mopar in terms of the HP ratings was the norm. I haven't found anything to suggest that this type of test was conducted by the factory in terms of the manifolds.
Re: Flow Chart Numbers on Exhaust manifolds [Re: moper] #1398376
03/07/13 11:15 PM
03/07/13 11:15 PM
Mesa, Arizona
Mesa, Arizona
On a flow bench
Re: Flow Chart Numbers on Exhaust manifolds [Re: dart4forte] #1398377
03/11/13 07:35 PM
03/11/13 07:35 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Mopar Muscle did a similar comparison of SB manifolds on a 300HP 360 crate. The results were just same as the BB manifold comparison posted up top; there was really no discernible difference in the entire lot. So called high performance manifolds seem to really be overrated for the BB and SB alike.
http://www.moparmusclemagazine.com/techa...st/viewall.html
Re: Flow Chart Numbers on Exhaust manifolds [Re: MarkZ] #1398378
03/12/13 06:28 PM
03/12/13 06:28 PM
dart1962_440 Offline
It'd be interesting to see how the 67 (which I think are 62-66) manifolds that 413 coronet shows in the picture flow. That's what early b bodies use and it would show if its really worth going to HP b body ones from later years.
Re: Flow Chart Numbers on Exhaust manifolds [Re: MarkZ] #1398379
03/12/13 06:50 PM
03/12/13 06:50 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
I guess I'm confused. I took from this that there wasn't a discernable difference between manifolds and headers. What didn't I understand?
Re: Flow Chart Numbers on Exhaust manifolds [Re: drew72] #1398380
03/12/13 06:57 PM
03/12/13 06:57 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
At that power level (300hp) there isn't much difference. As power goes up and with more aggressive cam timing, the HP difference between each exhaust type will be larger.
Similar to Hot Rod's 383 intake test a while back. In the mild state of tune there wasn't much more than a 10hp difference between best and worst, but at 450 hp or so, the spread was more like 40hp.
