another 727 question #1398279
03/06/13 08:51 PM
03/06/13 08:51 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
what will cause it to shift fine 1 to 2nd but third slides in. especially if your on it it will rev almost have to let out of the gas b4 it will shift to 3rd??
Re: another 727 question [Re: buck440] #1398280
03/06/13 09:13 PM
03/06/13 09:13 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The kickdown band (2nd) releases and the direct clutch applies during the 2-3 shift. It could be a shift timing problem, typically the kickdown band is out of adjustment; also, the sealing rings on the reaction shaft support may be leaking pressure. Does reverse work O.K.?
What valvebody? If automatic VB, the kickdown linkage could be out of adjustment.
John
Re: another 727 question [Re: DusterW2] #1398281
03/06/13 09:32 PM
03/06/13 09:32 PM
maryland
buck440 Offline OP
buck440  Offline OP
maryland
What valvebody? If automatic VB, the kickdown linkage could be out of adjustment.yep reverse is fine stock vb .
John
Re: another 727 question [Re: buck440] #1398282
03/07/13 08:19 AM
03/07/13 08:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'd be dissembling the front clutch for a look see. Cut seals, worn reaction shaft rings, Kick down linkage. Get Carl Munroe's book and read it. Like Jim said in the other post, slow and easy. They're not that hard.
Doug
