Need advice with burnt exhaust valve.
#1398043
03/06/13 03:06 PM
03/06/13 03:06 PM
Posts: 833 MN
hemidup
MN
What could be the cause of this? Too much advanced timing, too little retarded timing? It's a boosted motor with no signs of detonation.
Jerry Williams.
Re: Need advice with burnt exhaust valve.
[Re: pittsburghracer]
#1398047
03/06/13 04:53 PM
03/06/13 04:53 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Jerry, are they Manley valves?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: hemidup]
#1398060
03/06/13 09:19 PM
03/06/13 09:19 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Jerry I forgot your combo. What intake are you running?
XV intake manifold.
A couple of thing. First i read that the 90 deg elbow that your using is bad on air distribution. Also your intake is probably not helping. That being said you would of seen this way before. I believe you have over 300 passes on this combo. Soooooo. You said your A/F are in the 10s. Is this in the collector or primary pipes? I/m thinking you should have your injector for that cylinder checked?
[Re: MattW]
#1398061
03/06/13 10:18 PM
03/06/13 10:18 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
XV intake manifold.
This^^^^^^^
Ran into the same problem on a 4.6 ford mod motor with sullivan intake and super low profile elbow. The elbow didn't give the air enough room to "straighten" back out and always leaned the rear cylinders waaaaayyyyy out. installed a 4 hole carb spacer under it and the problem was fixed. The spacer creates an dam if you will and helps better distribute the air.
