4-wheel alignment '69 B-body is that possible or done? #1397985
03/06/13 12:36 PM
03/06/13 12:36 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Do alignment shops do or check four wheel alignment on a rear straight axle?
Or is that part of the alignment procedure and I just never noticed it being done?
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397986
03/06/13 12:41 PM
03/06/13 12:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Newer equipment with 4 heads will verify rear alignment, at least the last machine I used did. It was a Baer (Bear)?
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397987
03/06/13 12:45 PM
03/06/13 12:45 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
They can and should do that, but I bet some of them do not, especially if there is a young guy running the machine who thinks there is no value in checking a solid axle rear. The four wheel alignment can tell you thrust angles and camber angles of the rear, which aren't bad things to know.
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397988
03/06/13 01:02 PM
03/06/13 01:02 PM
Guitar Jones Offline
All of the newer equipment will read it, there are no adjustments though so unless it's really way off indicating a bent housing, axle or something there really isn't any thing you can do.
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: Guitar Jones] #1397989
03/06/13 02:19 PM
03/06/13 02:19 PM
couldn't a person add a thin plate as needed between the front shackle & the frame recess with the 4 holes to move the axle back on a particular side. Not sure about the cost benefit but just saying
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: RapidRobert] #1397990
03/06/13 02:29 PM
03/06/13 02:29 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
yes they make shims just for that
http://www.hotchkis.net/mopar_thrust_angle_shims.html
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: RapidRobert] #1397991
03/06/13 03:01 PM
03/06/13 03:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
But that adjustment is never included in a typical shop "4 wheel alignment"
On our older mopars, if a typical shop gives you a choice between 2 wheel and 4 wheel alignment the 4 wheel will give you no benefit. The "4 wheel alignment" is designed to give them time to make adjustments to the rear wheels, which they are not going to do with our leaf spring cars with a preset alignment price.
They are going to hook up the same alignment heads to for a 2 wheel vs. 4 wheel alignment. And the machine will read out your rear wheel numbers automatically. All the places I've gone to print the wheel wheel numbers, but I'm not sure that is an automatic thing.
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: autoxcuda] #1397992
03/06/13 03:30 PM
03/06/13 03:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Every machine Ive used in the last 30 plus years read the rear.It gives the thrust angle and toe.Just dont offer to do a rear alingment on a Vette with shim packs and rusty bolts.What a pain that was.Rocky
Chrysler Firepower
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: therocks] #1397993
03/07/13 09:57 AM
03/07/13 09:57 AM
Ohio
Super Coupe Offline
Super Coupe  Offline
Ohio
Haha! Stinking plastic Pigs! Gawd how I hate em after growing up repainting them! 6yrs old, they'd already have 5 crud paintjobs over the original GM garbage job... Ugh...
Anyways, I was just thinking about this topic last nite as a finally dug into my latest issue of Hemming Muscle Machines. They tried to run down the authority of the 70 HEMI Charger's handling. But I've had enough B-bodies to know their assertion's just shouldn't be true about wandering and floating at surface street speeds. So I was wondering if it wasn't running something like an "authentic" alignment spec? Like would allow a skinny set of bias ply's be happiest instead of actual radial rubber's more agressive specs? I remember when Radials were pretty new and the tire shop's insisted on using the factory spec's instead of adapting Radial specs to older cars. Nobody enjoys driving a car that dogtrack's because the rear alignment hasn't been checked and accordingly shimmed for correction of line assembly after a rebuild. But who either enjoy's driving a car at less than moderate hiway speed's which isn't 'tuned' for the tires it's wearing? I won't diss the car for what may be, but I wonder if it wasn't set up for tires different than as tested? I know that none of my Coronet's required much input from me at any speed where forward was the goal!
The name's Bondo. Jams Bondo Tonight I'm dining with Clia Torrez
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: TC@HP2] #1397994
03/07/13 11:22 AM
03/07/13 11:22 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
So it would show if the axle housing is bent also?
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397995
03/07/13 11:42 AM
03/07/13 11:42 AM
After getting the front aligned then at home should a person add shims/plates on the front shackle to move the rear axle back on whichever side as needed till the wheelbase (spindle center to axle center) is identical side to side or would that not be precise enough?
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: RapidRobert] #1397996
03/07/13 12:25 PM
03/07/13 12:25 PM
The alignment machine is not going to read the wheel base. All it will tell you on the rear is camber and toe for each of the two rear wheels and the total toe which will give you a thrust angle. Rear alignment specs do not generally affect how a vehicle drives.
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: Guitar Jones] #1397997
03/07/13 02:09 PM
03/07/13 02:09 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
I know you wrote "generally" but does that mean because "usually" the rear axle is in alignment or not that much out of alignment to not cause an issue? I just don't see how the rear axle/wheels could not have some kind of affect on how a vehicle drives/steers/handles?
Appreciate all of the replies so far
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397998
03/07/13 05:29 PM
03/07/13 05:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ever see a car going crab style down the road.That because the rear is way out.Ive seen quite a few here.Most were rear drives.It will want to go to the side.You pretty much have to steer away from the side that it wants to pull toward.Rocky
Chrysler Firepower
Re: 4-wheel alignment '69 B-body is that possible or done? [Re: A12] #1397999
03/07/13 06:09 PM
03/07/13 06:09 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Correct, usually, the rear is not so grossly out of line that it causes issues, plus if the variations are minor, most drivers won't know they even have an issue. However I'm sure we have all seen examples that are waaay out of wack too.
Rear alignment can impact the way it drives nad handles by the classic "dog leg" or crab walk. This can cause excessive wear on the tires as well as making the car feel inconsistent between left to right turns.
During a turn, a leaf spring car's wheelbase changes as the springs compress and extend. If you have excessive angles with the rear housing, this motion becomes creates the inconsistent feeling between left and right turns since this motion is not transmitted equally side to side.
Certainly bent housings can impact things as well if it is bent into a toe or camber direction that again, creates a disparity between left and right. However, this can sometimes actually create an advantage to the handling if the bend produces a nominal amount of toe out or negative camber. I have known oval track racers who purposly bent rear housings to add camber to a live axle. It accellerates wear on parts as well, so its a touchy proposition on a street car.
So yes, understanding where the particular angles are on the rear is helpful and knowing them means you can correct/modified to some degree. If a shop will offer a 4 wheel print out, I certainly would take them up on it, but like Steve pointed out, for a live axle RWD car, it isn't going to include any adjustments on the rear, just information on where it is.
