Accumulator on RB Block #1397971
03/06/13 11:07 AM
03/06/13 11:07 AM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
How do I add an accumulator (canton/moroso/...??) to a RB with a Milodon dual line oil pump set-up? If I could avoid a remote oil filter I would prefer that. I want to lose the drill motor priming ritual.
Re: Accumulator on RB Block [Re: Dduster] #1397972
03/06/13 12:32 PM
03/06/13 12:32 PM
Years ago I installed a Moroso 3 quart on a 426 Hemi block by enlarging one of the rear(passengr side, I think) cross over oil passages
Re: Accumulator on RB Block [Re: Cab_Burge] #1397973
03/06/13 12:38 PM
03/06/13 12:38 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Moroso makes an adapter for the oil filter mount.
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Accumulator on RB Block [Re: lowflyingdart] #1397974
03/06/13 12:40 PM
03/06/13 12:40 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
I installed a "T" in the line to the remote oil filter mount.
Re: Accumulator on RB Block [Re: Dduster] #1397975
03/06/13 02:53 PM
03/06/13 02:53 PM
AndyF Offline
AndyF  Offline
The Milodon cover can be drilled and tapped for a fitting. Or use one of the ports at the back of the block.
Re: Accumulator on RB Block [Re: AndyF] #1397976
03/06/13 06:00 PM
03/06/13 06:00 PM
Smithfield, Rhode Island
Mulehead Offline
Happy Birthday Mulehead  Offline
You can see the gray plug at the bottom on oil pump.Tee there.
Ain't nuthin like a HEMI !
Re: Accumulator on RB Block [Re: Mulehead] #1397977
03/06/13 06:01 PM
03/06/13 06:01 PM
Mulehead Offline
Re: Accumulator on RB Block [Re: Mulehead] #1397978
03/08/13 10:37 AM
03/08/13 10:37 AM
Livermore, CA
Dduster Offline OP
Dduster  Offline OP
Livermore, CA
Thank You everyone.
