Re: NHRA oil retention device question
[Re: '72CudaRacer]
#1397927
03/05/13 11:48 PM
03/05/13 11:48 PM
Posts: 2,475 SW Ohio
cgall
SW Ohio
I did it in Div. 3 from '93 to '01 before the diaper rule, my experience is that they check safety stuff at every race, other stuff sporadically. If you fill out your tech card completely, you are 90% done. If you still have the serial number from your balancer and sheild that you can put on the tech card, that should get you through. I had all my numbers in my log book, no one ever checked my balancer or trans blanket. They did check my helmet, jacket, seat belts, battery disconnect.
I know a guy with a 9-second bracket car that bought a cheepo diaper (ramjet) and sliced and diced it with scissors and put it back together with velcro and passed tech for S/G. This is a back-half B-body with a RB engine and K-member. Just having the diaper on there is is the ticket.
[Re: 2QUICK4U]
#1397929
03/06/13 12:04 AM
03/06/13 12:04 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
I use cheap one from jegs. My drag link goes through pan. I cut it up an made it fit.
Shawn Jennings
[Re: '72CudaRacer]
#1397931
03/06/13 05:07 AM
03/06/13 05:07 AM
Posts: 345 iowa
wesw
iowa
the csi shield you will need to update it. the balancer they might let that slid. as for the engine diaper your going to need one made with the hole in it for the steering link. cutting a hole in it is a no no.
598 ci predator
[Re: reknapp52]
#1397933
03/06/13 01:06 PM
03/06/13 01:06 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
DRE will make a diaper to fit your pan like a glove..
[Re: '72CudaRacer]
#1397934
03/07/13 10:50 AM
03/07/13 10:50 AM
Posts: 89 Woodbury, CT.
mcduff
Woodbury, CT.
I run the SS Milodon Pan with the centerlink hole and had DRE make my diaper..Like Al said it fits like a glove. I also had concerns about the centerlink opening so I fabricated some bellow like sleeves out of kevlar welding arm protectors to seal up the opening. I will try and post some pictures when I get back to the shop
Brett Miller 447 W9
