727 problem #1397885
03/05/13 09:45 PM
03/05/13 09:45 PM
nc
E
emarine01 Offline OP
E
nc
Symptoms....Hard to drive in reverse and seems slow..needs rpms to move, no drive in low @ idle... needs rpms to move, Drive seems fine in D position, Mostly stock 727 with good clutches & bolt on sprag 5k vert... What broke??
Re: 727 problem [Re: emarine01] #1397886
03/05/13 10:12 PM
03/05/13 10:12 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Manual valve body ?
Re: 727 problem [Re: emarine01] #1397887
03/05/13 10:16 PM
03/05/13 10:16 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
TRANSMISSION Would be my gess. Take it apart and find out would be a good start.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: 727 problem [Re: emarine01] #1397888
03/05/13 10:29 PM
03/05/13 10:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check line pressure.. did it just start or getting
worse... band adjustments ok
Re: 727 problem [Re: dOc !] #1397889
03/05/13 10:42 PM
03/05/13 10:42 PM
nc
E
E
nc
Manual valve body ?
No stock
Re: 727 problem [Re: MR_P_BODY] #1397890
03/05/13 10:52 PM
03/05/13 10:52 PM
nc
E
E
nc
Hey Mike, I race in drive and it seems fine, I had the truck jacked up in the shop and in neutral the wheels turned easy by hand rolling forward and very hard to turn in reverse, this is with the front hubs unlocked, so I started it up and found it drives the wheels fine in D... then they will just about stop rolling in low and same in reverse, It may be the band cause It in not engaged in drive, just low and reverse, is there a possibility that band broke?
Re: 727 problem [Re: emarine01] #1397891
03/05/13 11:23 PM
03/05/13 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think its broke... but I would drop the pan
and have a look see... maybe just the spacer bent
Re: 727 problem [Re: MR_P_BODY] #1397892
03/06/13 12:12 AM
03/06/13 12:12 AM
nc
E
E
nc
Does the spacer look like a piece of flat bar....
Re: 727 problem [Re: emarine01] #1397893
03/06/13 12:15 AM
03/06/13 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
yeah
Re: 727 problem [Re: MR_P_BODY] #1397894
03/06/13 01:08 AM
03/06/13 01:08 AM
nc
E
E
nc
Its not bent, To readjust it its tighten till snug and back off 2 turns ? I think the servo is hanging up, how much air pressure to test it?
Re: 727 problem [Re: emarine01] #1397895
03/06/13 01:47 AM
03/06/13 01:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess thats the spec for your valve body ... 2
should be ok... you might call the valve body company
to get the proper spec... about25#- 30# air will be fine
Re: 727 problem [Re: emarine01] #1397896
03/06/13 08:56 AM
03/06/13 08:56 AM
NC
440Jim Offline
440Jim  Offline
NC
As discussed, it sounds like something in the rear band, linkage, servo, etc. I don't know how familiar you are with a TF 727, but be sure you are looking at the rear band, and not the front one.
This topic has some images of the rear linkage.
Rear Band linkage
Look closely at the rear servo for proper action, not sticking etc. If possible, remove the valve body and air check the rear servo action. Be careful, fluid is likely to spray when you do it. 30 psi is plenty, 20 might do it.
Re: 727 problem [Re: 440Jim] #1397897
03/06/13 11:54 AM
03/06/13 11:54 AM
nc
E
E
nc
Nice pic Jim The VB is stock Mopar mike, The servo seems fine, The rear band was kinda loose like 6 turns from the drum, Its still hard to turn the wheels by hand in reverse and easy in forward, The fluid was clean and just a little trash in the pan like a 1/4 teaspoon of clutch material, Its been over 150 passes the last time the pan was down, It looks like the spline in the rear drive shaft has a 1/2 turn twist in it and wont move in or out, I will have to isolate rear end from the transfer case to trouble shoot further thanks for the help guys
Re: 727 problem [Re: emarine01] #1397898
03/06/13 12:32 PM
03/06/13 12:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
6 turns is a lot
Re: 727 problem [Re: MR_P_BODY] #1397899
03/06/13 02:58 PM
03/06/13 02:58 PM
nc
E
E
nc
6 turns is a lot
Yep, it sure is, I think the band was slipping, not sure on the hard to turn in reverse yet, I never use low 1 just reverse, the truck has been makin good power so we have been blowing off all 4 wheels and upshifting to hi 3 in the first few feet off the line, I did notice on the tach play back I hit the 7200 chip on the top of the 1-2 shift & the top of the 2-3, thats a new thing but the starting line has been real deep and wet so far this year.. lots of rain.. Ill keep foolin with it till I get it figured out
Re: 727 problem [Re: emarine01] #1397900
03/06/13 03:25 PM
03/06/13 03:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
The hard to turn in reverse in pretty normal, it has to do with the over running clutch/sprag, it spins in one direction but locks up in the other and forced you to have to spin more mechanicals with in the trans like planitary.s and drums,,,kinda the short explaination.
Re: 727 problem [Re: dartman366] #1397901
03/06/13 10:27 PM
03/06/13 10:27 PM
NC
440Jim Offline
440Jim  Offline
NC
I am a little concerned that you said it is spinning the tires in "D" with a factory valve body. I haven't heard any sypmtons of a rolled (or partially damaged) sprag, but it is a possibility. Those parts come in contact with the rear drum and can hamper motion in one direction. The harder than normal turn in reverse might just be due to the yoke spline issue you mentioned. I can't be sure.
Re: 727 problem [Re: 440Jim] #1397902
03/07/13 12:43 AM
03/07/13 12:43 AM
nc
E
E
nc
Thankx Bill, Jim we always run out of D on the sprag, first gear lasts about a tenth of a second then it shifts second gear, We use first gear just to get the weight of the tires 450lbs and drive line moving, The sprag seems to handle it ok, I know you guys dont use first in the box but I thought it was on first gear decell that messed up the sprags? One more abnormal thing... wheels are turning in neutral more than normal... I cant stop them by hand now, I have to use the brake, Before I could. Also about how much fluid comes out from dropping a stock pan, engine was just run and vert was full?
Re: 727 problem [Re: emarine01] #1397903
03/07/13 05:11 PM
03/07/13 05:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Tires spinning on jack stands isn't unusual but if the car creeps forward in Neutral the rear clutch is dragging.....could also explain the lazy Reverse.
Stock pan holds about 4 qts.
Re: 727 problem [Re: John_Kunkel] #1397904
03/07/13 05:31 PM
03/07/13 05:31 PM
nc
E
E
nc
Tires spinning on jack stands isn't unusual but if the car creeps forward in Neutral the rear clutch is dragging.could also explain the lazy Reverse.
Thankx John... The truck wont move in N with it on the ground but with the wheels off and on stands I cant stop the axles from turning by hand.... They used to roll real slow in N with no power behind them or start and stop on the stands with change in rpm, I can feel a slight jerk in N on the ground when we start the engine then it slips into N with no movement.... as you said it feels like a clutch pack is stuck or dragging then frees up..... It may be time to start going thru the spare trans... .... I would like to thank everyone for the input... I am not too savvy on torqueflites
