1970 RR airbox rear bolt, stud, screw? #139771
10/21/08 09:55 PM
10/21/08 09:55 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
The rear mounting device on a 70 air grabber airbox, you know the one no one knows is there until you break it cause it sits clear to the rear all by itself, is it a screw or bolt that goes through a clip in the hood or is there a stud that comes out of the hood and just a nut goes on it? I can see on my hood where it looks like some type of a clip would go. Anyone got pictures of what goes there? TIA
Re: 1970 RR airbox rear bolt, stud, screw? [Re: gregok] #139772
10/21/08 11:52 PM
10/21/08 11:52 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
There is a clip that slides into that hole in your hood. Should use a course thread screw into it just like the ones that hold the seal to the airbox.
Re: 1970 RR airbox rear bolt, stud, screw? [Re: hemi70se] #139773
10/22/08 06:37 AM
10/22/08 06:37 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks! That is what I was looking for.
