275- 60- 15 E.T. Street Radial pro on 12" wheel #1397672
03/05/13 01:40 PM
03/05/13 01:40 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I was looking at running a 275 E.T. Street Radial on my car this year but not sure if I can run them on my 12" wheels. I have seen guys do it with bead locks but not sure about with no bead locks.
67' charger 499 RB 10.57 at 127
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397673
03/05/13 01:50 PM
03/05/13 01:50 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
10" wheel yeah....but not a 12"....way too wide of a rim.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397674
03/05/13 02:08 PM
03/05/13 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
12 is way to wide. I'd think 10 would be about it
Coming soon!!!!
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Mr.Yuck] #1397675
03/05/13 02:32 PM
03/05/13 02:32 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
the mustang guys have done it on 12" wheels, maybe better info over on yellowbullet.com
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: prochargedhemi] #1397676
03/05/13 02:57 PM
03/05/13 02:57 PM
bigfork mn
bigfork mn
Yeah I posted it on the bullet to. People go up to 13" wheel it looks like but only with double bead locks. I had read on there befor people had been doing it but it doesnt look like it is to safe without the double bead locks.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397677
03/05/13 05:19 PM
03/05/13 05:19 PM
I've used the MT ET Street Radials 315x60x15 on both 10 and 12 inch rims, no problems on either Not bead locks, no rim screws, no tubes If you have the rims, I would try them
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Cab_Burge] #1397678
03/05/13 05:51 PM
03/05/13 05:51 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
There's a pretty big difference between a 275 and a 315.
(that's what she said) LOL
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Duner] #1397679
03/05/13 08:06 PM
03/05/13 08:06 PM
ccarson Offline
ccarson  Offline
like 40mm
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397680
03/05/13 08:06 PM
03/05/13 08:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
100% yes u can do it,and personally i think it looks awesome.I see it all the time on radial cars.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397681
03/05/13 10:30 PM
03/05/13 10:30 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Hey have you been working on your car then this winter? We should get together sometime and have a few beers when I'm home this winter.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: fishy340] #1397682
03/06/13 12:14 PM
03/06/13 12:14 PM
bigfork mn
bigfork mn
Without beadlocks?
Hi clint. No havent been working on it at all. Havent even had the cover off since fall. Just starting to think about it. That 660 outlaw street class might be a good one for ya.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: fishy340] #1397683
03/06/13 12:35 PM
03/06/13 12:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
to each his own I think it looks silly when the rim is wider than the tire, but then again I don't like 18-20" rims on old muscle cars either.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397684
03/06/13 01:34 PM
03/06/13 01:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have ran them on the 12" wide double bead lock with no issue
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Mr.Yuck] #1397685
03/06/13 02:42 PM
03/06/13 02:42 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
i wouldn't hesitate to do it. depending on how fast your going I would personally go double beadlock.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: dragram440] #1397686
03/06/13 03:54 PM
03/06/13 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe I'm different but I go by what the manufacturer
says... they have more time at this... sure maybe it
wont come off the rim.... JMO
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: MR_P_BODY] #1397687
03/06/13 04:45 PM
03/06/13 04:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what would be the advantage of a 12" rim vs. a 10" seems to me you'd have less side wall on the 12's.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Mr.Yuck] #1397688
03/06/13 05:48 PM
03/06/13 05:48 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Need beadlocks to run it on a 12.
One day I will have something cool here.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Mr.Yuck] #1397689
03/06/13 05:51 PM
03/06/13 05:51 PM
Temperance, MI
P
P
Temperance, MI
like any tire, you will get a wider contact patch
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: prochargedhemi] #1397690
03/07/13 11:35 AM
03/07/13 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
if the tread width of a tire is 10.5, as is a 275/60/15 how would a 12" help? I under stand if you were going from an 8" rim to a 10. I would seeem to me you'd lose the "wrinkle wall" effect. Are you saying buy placing the tire on a wider rim you can make the tread width 12"??? I don't see how that is possible. I run a 9" rim and 275's, my contact patch is pretty much all of the tread width.
Re: 275- 60- 15 E.T. Street Radial pro on 12" wheel [Re: Mr.Yuck] #1397691
03/07/13 02:02 PM
03/07/13 02:02 PM
bigfork mn
bigfork mn
Maybe some of you didnt read the whole thread. I HAVE 12" WHEELS. IM NOT BUYING DIFFERENT WHEELS. If I have to run a bigger tire I will. Not that big of deal. I see alot of the 275 tire guys run 12" wheels for a wider contact patch. I didnt ask how it looked. I asked if you can do it. Thanks
