modifying a factory street hemi intake #1397616
03/05/13 11:49 AM
03/05/13 11:49 AM
an8sec70cuda Offline OP
I have a factory inline street hemi intake manifold that's going on a mild stroker hemi...500+ cubes, 10:1 compression, mild roller, etc.
It's going to have a pair of Carter 9755S 750 cfm carbs on it. The car has 3.54 gears and is a 4 speed.
The manifold is unmolested. I haven't mocked it up yet, but it looks like I need to enlarge the front bores in the intake for these carbs to fit. Anything else I should do? Seems like the Vanke mod isn't a good idea for a street car...this car is 99% street driven. Any advice?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: modifying a factory street hemi intake [Re: an8sec70cuda] #1397617
03/05/13 12:04 PM
03/05/13 12:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Vanke mod would probably work fine in your application.
2011 Drag Pak Challenger
Re: modifying a factory street hemi intake [Re: an8sec70cuda] #1397618
03/05/13 12:12 PM
03/05/13 12:12 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
From Arruzza's website.
Street Hemi intake manifold . New from Mopar Performance . Every street Hemi intake I use on my engines or sell outright has the Arlen Vanke modification . My experience has proven this style intake MUST be modified in this way. The fuel distribution is far superior and the torque band starts sooner and finishes much later. There is no reason to run a stock manifold .
For many years I always heard that this modification hurts the bottom end, I never experianced that until I ran a set of 67 RO23 / WO23 750 cheater carbs , which is what Chrysler used on the “vanke” modifiefd intakes , Yes, they did lose bottom end, but that was the carbs , not the intake. If you have a crate hemi that needs a helping hand or are building a new engine , this Mopar intake with my machine work will deliver the goods
http://www.arruzzahighperformance.com/Parts/Parts.html
With 500 cubic inches I wouldn't think torque would be an issue so drive-ability should be fine.
Re: modifying a factory street hemi intake [Re: an8sec70cuda] #1397619
03/05/13 12:18 PM
03/05/13 12:18 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Yes do the Vanke.
Re: modifying a factory street hemi intake [Re: SNK-EYZ] #1397620
03/05/13 12:21 PM
03/05/13 12:21 PM
That's what I was thinking too, but I've read a couple different things online saying it wasn't a good idea for a street car. I don't see it being a problem since this motor will have a 4.25" stroke in it (not sure on bore size yet). I'm asking here though b/c I have zero experience w/ this manifold and wanted to see if anyone has done something similar.
CHIP
Re: modifying a factory street hemi intake [Re: an8sec70cuda] #1397621
03/05/13 12:30 PM
03/05/13 12:30 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
I have asked lots of people about it before, and on a STROKED HEMI, there is actually NO DOWNSIDE to doing it....just more power!!!! Just do it!
Re: modifying a factory street hemi intake [Re: an8sec70cuda] #1397622
03/05/13 12:31 PM
03/05/13 12:31 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Back about 1990 I took off a stock Hemi intake and installed a Vanke modded intake on a "Fresh" stock 426 Hemi.
I noticed a small amount of bottom end torque difference but not so much that it was any problem with drive-ability.
I had the mod done on my intake on my 572 but I haven't fired it up yet much less driven it but I don't see street drive-ability as an issue.
Re: modifying a factory street hemi intake [Re: SNK-EYZ] #1397623
03/05/13 09:07 PM
03/05/13 09:07 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Is the mopar intake with the Vanke mod better than the the stage 5 single plane intake???? TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: modifying a factory street hemi intake [Re: tpabayflyer] #1397624
03/06/13 12:10 AM
03/06/13 12:10 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
No. But it fits stock aircleaners, hoods, Linkage, brackets etc.
Sheldon
Re: modifying a factory street hemi intake [Re: RUNCHARGER] #1397625
03/06/13 12:16 AM
03/06/13 12:16 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Sheldon
I have a 69 aircleaner base for the stageV intake with edelbrock carbs if you are interested...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
