Re: 71 satellite LCA setup ?
[Re: Dan@Hotchkis]
#1397519
03/05/13 05:51 PM
03/05/13 05:51 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
I guess maybe the really basic question I should of asked is once the suspension assembly is together, Tbars, LCA's, etc...should I leave the pivot shaft nut semi tightened, crank up the T-bar bolt a few turns as suggested then lower and adjust ride height once motor is installed & torque the LCA nut down then....or does it matter if the pivot shaft nut if torqued down at the initial install?
Thanks for all the help, sorry for the lengthy questions...
[Re: edp]
#1397522
03/06/13 01:39 PM
03/06/13 01:39 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
If you tighten rubber bushings while the front end is up high, as in no weight on it/not at operating height, then put weight on it, the rubber in the bushings will stretch around the shaft, and could eventualy tear, and so not last as long as it should. You want the rubber in a 'neutral' state, no stretch while at operating height. That way when the front end goes up and down over bumps and into pot holes the rubber can now stretch in both directions without over stretching in one direction.
The way I learned it was to "Put weight on the front end before tightening the bushings" No engine in the car? Then use weights like barbells that equal the weight of the engine. Some people say you should have the weight of a driver in the driver's seat when setting front end height.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
