Small Block in a Big Block car
#1397339
03/04/13 08:27 PM
03/04/13 08:27 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Hello all. I found a factory 383 'Cuda and I've put most of my funds into getting the car, which is a roller, so I don't have the cash to get my 440 rebuilt right now. But I would like to drive the car and I've got a perfectly good 318. Would that involve installing a small block K frame and other things and be more trouble than it's worth? Thanks
-ERIC
Re: Small Block in a Big Block car
[Re: Nimbus426]
#1397342
03/04/13 09:04 PM
03/04/13 09:04 PM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
Take your time. Do the proper 383. You'll be happier and spend less in the long run.
This is the land of the free
because of the brave
[Re: rbstroker]
#1397343
03/04/13 09:27 PM
03/04/13 09:27 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
Okay that doesn't sound too bad. I was expecting worse. The 318 is complete and running, that is the only reason I'd consider this option instead of just saving for a big block. I also have one more question. The fender tag is long gone. The VIN and body stamps are there and match up. Would the missing fender tag bring down the value of the car? I don't think I'll be selling the car anyway, but it would be nice to know in case I ever get in a bind and need to sell. Thanks
-ERIC
[Re: Nimbus426]
#1397345
03/05/13 05:29 PM
03/05/13 05:29 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
A car with fender tag, broadcast sheet, and numbers matching engine and trans will always be worth more than one without one or more of those things. Sounds like you're already lacking the original engine and trans, so I wouldn't sweat the lack of a fender tag too much.
BTW, congrats on your purchase. Good luck with it.
[Re: Nimbus426]
#1397347
03/05/13 07:38 PM
03/05/13 07:38 PM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Thank you. I've had a few 'Cuda projects in the past but they were so far gone I couldn't do much with them and ended up selling. This one will be much much easier to restore because of its minimal rust issues. And yes because the original drivetrain is gone and fender tag missing I just planned on skipping the 383 and making it a 440 'Cuda
then don't worry about the fender tag , if you don't have the broadcast sheet you have no way of making an accurate tag and it will be easily spotted as not being a factory original so it will not add any value to the car. Get a tag from a /6 volare and have some fun ....
[Re: pnypwr]
#1397350
03/05/13 11:04 PM
03/05/13 11:04 PM
Posts: 5,895 Florida
Locomotion
Radiator inlet/outlets are in a different location and bellhousing bolts are different between big & small block. If you use a 904 with the 318, the driveshaft will need to be longer & have a different slip spline than with a 727. Match the rear yoke size.
not only is the bellhousing bolts different the bolt pattern is different...cant bolt a small block trans to a big block engine or vis a vie
That's what I meant - the pattern. Fingers typing faster than the brain is thinking.
