Indy-Brocks #1396986
03/03/13 11:27 PM
03/03/13 11:27 PM
North East Coast
harborracer Offline OP
North East Coast
When a set of heads is referred to as Indy-Brocks does this mean they are Eldelbrock heads then sent to Indy for porting?
Re: Indy-Brocks [Re: harborracer] #1396987
03/03/13 11:29 PM
03/03/13 11:29 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Never ever ever is a set of heads referred to as Indy-Brock's.
Re: Indy-Brocks [Re: joshking440] #1396988
03/03/13 11:31 PM
03/03/13 11:31 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
But, if you want to talk about the Indy T/A heads, which start life as a raw bare small block edelbrock casting and the fitted with big block Mopar rockers and no push rod pinch area line a typical small block and can flow over 300 Cfm then I can help ya there.
Re: Indy-Brocks [Re: harborracer] #1396989
03/03/13 11:39 PM
03/03/13 11:39 PM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Yes they are bare edelbrock castings remachined & fitted out at ICH.
Commonly refered to as Indy-Brocks
Re: Indy-Brocks [Re: CRIKEY] #1396990
03/04/13 06:34 AM
03/04/13 06:34 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Indybrocks aren't just ported. The pushrod holes are moved out to get rid of the pinch, and big block rockers are used. Some people say they don't flow anymore than a fully ported edelbrock, but in my experience, I gained a few tenths going from ported eddies, to the now called t/a head.
Re: Indy-Brocks [Re: joshking440] #1396991
03/04/13 08:49 AM
03/04/13 08:49 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Yeah dude, Indy-Brocks that's what my dad calls his anyway.
Re: Indy-Brocks [Re: SpareParts] #1396992
03/04/13 11:19 AM
03/04/13 11:19 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If Josh says there are no such thing as Indy-Brocks then he is correct,he would know.I apologize to all my customers for referring to them as Indy-Brocks in the past and will correct my verbage to Edelbrocks done by Indy."The luck of the draw"
Re: Indy-Brocks [Re: B G Racing] #1396993
03/04/13 11:24 AM
03/04/13 11:24 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
maybe we can start calling the Elindys but it doesnt sound no where as good as Indybrocks
Re: Indy-Brocks [Re: sixpackgut] #1396994
03/04/13 11:29 AM
03/04/13 11:29 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
At least we didn't call them Brockindy. That sounds like a movie star.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy-Brocks [Re: pittsburghracer] #1396995
03/04/13 11:43 AM
03/04/13 11:43 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
John,I guess we shouldn't referr to them as Indy-Brocks anymore and just as Edelbrock heads that can be purchased from Indy and many other sources since the"Indy Messiah" has spoken and we are only pawns sitting at a card table and subject to "the luck of the draw"I'am holding Aces and Eights
Re: Indy-Brocks [Re: B G Racing] #1396996
03/04/13 12:46 PM
03/04/13 12:46 PM
Washington
skrews Offline
skrews  Offline
Washington
I call mine fixer uppers.
Re: Indy-Brocks [Re: skrews] #1396997
03/04/13 01:15 PM
03/04/13 01:15 PM
my 408 sure likes them!
Re: Indy-Brocks #1396998
03/04/13 07:48 PM
03/04/13 07:48 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my 416 made just shy of 650hp with a set of them there indybrocks
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Indy-Brocks [Re: B G Racing] #1396999
03/04/13 07:56 PM
03/04/13 07:56 PM
V
viperblue72 Offline
viperblue72  Offline
V
Well I guess there is no such thing as an indybrock, and we aren't allowed to call them that anymore.
Re: Indy-Brocks [Re: viperblue72] #1397000
03/04/13 09:23 PM
03/04/13 09:23 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Indy Brock could mean any edelbrock head we sell.
I bet I spend 1 hour a week alone explaining to people that just because they bought edelbrock heads from us that they are anything other than just a standard edelbrock.
So to avoid future confusion for people the T/A head should marketed better.
Re: Indy-Brocks [Re: joshking440] #1397001
03/04/13 09:28 PM
03/04/13 09:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
so whats the difference in the heads?
Re: Indy-Brocks [Re: Quicktree] #1397002
03/05/13 09:23 AM
03/05/13 09:23 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Well I guess the best way to explain the difference is that its an aluminum true T/A Head.
The pushrod is not in the port at all, we get the castings raw, so its easy for us to relocate the pushrod and remove all the unnecessary material from the intake ports.
We also machine the rocker stands differently as to accept any standard set of big block rockers.
Add the CNC porting and you get a small block head that will flow over 300 real easy and is reasonably priced
Re: Indy-Brocks [Re: viperblue72] #1397003
03/05/13 05:39 PM
03/05/13 05:39 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
Glad to hear that setup worked out for you.
Re: Indy-Brocks [Re: joshking440] #1397004
03/05/13 05:45 PM
03/05/13 05:45 PM
AndyF Offline
AndyF  Offline
It is a clever idea. If the Mopar engineers had done that trick years ago they could've added performance without adding much cost. Using the BB rocker arms is a cost effective trick.
Re: Indy-Brocks [Re: joshking440] #1397005
03/05/13 05:50 PM
03/05/13 05:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
though that was your job
