oil pan/dipstick question 440 #139687
10/21/08 06:22 PM
10/21/08 06:22 PM
Anonymous OP
Anonymous OP
i recently came across a real strong 440 engine out of a truck(78) and want to drop it in my 72 roadrunner.i noticed that the 440 block has a metal plug in the hole where the dipstick tube drops into,the truck motor uses a dipstick that drops into the oil pan.is there any easy way to remove that metal plug?or am i stuck trying to adapt the oil pan tube setup into my b body oil pan?the truck pan is different obviously.this motor had alot of work done to it $ wise and is waiting in my garage to go into my rr.any help would be great.thanks!
Re: oil pan/dipstick question 440 #139688
10/21/08 06:29 PM
10/21/08 06:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would think you should be able to punch that plug out once the pan is off. Knock it out the top.
Re: oil pan/dipstick question 440 [Re: buildanother] #139689
10/21/08 07:25 PM
10/21/08 07:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I had to do this with mine. Punches out pretty easy from underneath.
