Door Panel Removal on a 2002 Ram 1500 #1396569
03/03/13 11:47 AM
03/03/13 11:47 AM
Iron Station, NC
furygt Offline OP
furygt  Offline OP
Iron Station, NC
I need to remove the driver's side door panel from my 2002 Ram 1500 Quad cab (same as a 2003). I have removed all of the screws and the interior corner piece by the front bottom edge of the door glass and tried to gently pry it off but it will not budge. Since it is a plastic panel, I don't want to crack it. I need to replace a blown speaker in the door.
If anyone has done this, please let me know what step etc. that I am missing. I did have to have the door glass replaced a few years ago and hope that the panel was not glued back on.
Any and all help is appreciated.
Thanks,
Bill
Re: Door Panel Removal on a 2002 Ram 1500 [Re: furygt] #1396570
03/03/13 12:01 PM
03/03/13 12:01 PM
Amherst,NY
challengermike Offline
Amherst,NY
You have to pick straight up for it to come off. Not pull out. Theres no clips just tabs that side into holes on the door.
Re: Door Panel Removal on a 2002 Ram 1500 [Re: challengermike] #1396571
03/03/13 12:20 PM
03/03/13 12:20 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
At least that's how my 04 is
Re: Door Panel Removal on a 2002 Ram 1500 [Re: Dcuda69] #1396572
03/03/13 01:16 PM
03/03/13 01:16 PM
Iron Station, NC
furygt Offline OP
furygt  Offline OP
Iron Station, NC
Thanks!!! A 2004 is the same body style so that should work.
Bill
Re: Door Panel Removal on a 2002 Ram 1500 [Re: furygt] #1396573
03/03/13 02:03 PM
03/03/13 02:03 PM
Amherst,NY
Amherst,NY
I owned an 04 and now own an 02 so i know they are the same. I learned the hard way on the 04 though, LOL
Re: Door Panel Removal on a 2002 Ram 1500 [Re: challengermike] #1396574
03/03/13 04:21 PM
03/03/13 04:21 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I took my 04 door panel off a few years back to replace the door lock, removed all the screws and it came right off.
