Bench Seat Backs #1396541
03/03/13 10:38 AM
03/03/13 10:38 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
I hope someone can help tell me what hardware is needed to attach the seat backs to the seat bottom. I took them apart 8 years ago and moved a couple of times and I think maybe tossed it.
It is front bench out of a 70 duster.
Howard
Re: Bench Seat Backs [Re: Howard] #1396542
03/07/13 02:13 PM
03/07/13 02:13 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Does anyone know?
Re: Bench Seat Backs [Re: Howard] #1396543
03/13/13 11:45 AM
03/13/13 11:45 AM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Anyone???
Re: Bench Seat Backs [Re: Howard] #1396544
03/13/13 02:13 PM
03/13/13 02:13 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have a split bench seat out of my 71 Demon.
Come get it.
I live in Ohio.
Re: Bench Seat Backs [Re: demon440] #1396545
03/13/13 06:50 PM
03/13/13 06:50 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Demon 440 I just had my bench seat recovered, but I need to know what hardware holds the seat back to the seat bottom. If you could take a look at yours and tell me I would appreciate it.
Howard
Re: Bench Seat Backs [Re: Howard] #1396546
03/13/13 07:41 PM
03/13/13 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need a hinge with latch on each side. The hinges are attached to the seat back and go over a pin sticking out of the side of the bottom of the seat. They are held on the swivel pin with a washer with teeth on the inside where it slides over thwe pin. The center of the seat bottom has two brackets with pins that the seat back brackets slide onto. The side hinges have a plastic cover that goes over them to finish the look.
Re: Bench Seat Backs [Re: stumpy] #1396547
03/13/13 10:41 PM
03/13/13 10:41 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Thanks Stumpy. Do you have a picture of the washer with teeth on the inside? or know if they are available anywhere?.
Howard
Re: Bench Seat Backs [Re: Howard] #1396548
03/13/13 11:43 PM
03/13/13 11:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ace hardware. They look like the one on top if I remember right.
Re: Bench Seat Backs [Re: stumpy] #1396549
03/14/13 04:37 PM
03/14/13 04:37 PM
Central PA
Howard Offline OP
Howard  Offline OP
Central PA
Wow Thanks Stumpy. I'll head over to Ace and see if I can find them. Thanks again for the help.
Howard
