'63 to '64 door panel interchange #1396219
03/02/13 08:09 PM
03/02/13 08:09 PM
MN
ryangtogtx Offline OP
MN
Are 63 & 64 b-body door panels the same size?
Re: '63 to '64 door panel interchange [Re: ryangtogtx] #1396220
03/02/13 09:42 PM
03/02/13 09:42 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
They should interchange as the doors themselves are the same but they have the different interior patterns year/model...
Re: '63 to '64 door panel interchange [Re: QuickBpBp] #1396221
03/03/13 11:27 AM
03/03/13 11:27 AM
MN
MN
Thanks. That is what I was looking for.
Re: '63 to '64 door panel interchange [Re: ryangtogtx] #1396222
03/04/13 02:43 AM
03/04/13 02:43 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
63 is different, 64/65 are the same. I don't know if that goes for the panels as well, but the doors don't interchange.
Re: '63 to '64 door panel interchange [Re: ryangtogtx] #1396223
03/05/13 08:15 PM
03/05/13 08:15 PM
Randolph, Ohio--N.E. Ohio
Goat330 Offline
Goat330  Offline
63-65 post cars(2-dr. sedans) will interchange except for pattern differences.64 & 65 hardtops will also interchange with each other.
Re: '63 to '64 door panel interchange [Re: Goat330] #1396224
03/07/13 06:30 PM
03/07/13 06:30 PM
MN
MN
So are you saying 63 & 64 hardtops won't fit each other?
Re: '63 to '64 door panel interchange [Re: ryangtogtx] #1396225
03/07/13 10:15 PM
03/07/13 10:15 PM
Goat330 Offline
Goat330  Offline
A 63 hardtop has the same roofline as the sedan(63&64), the door panel follows that contour,has a portion on the rearward that raises slightly to match that shape.The 64 hardtop has a different roofline and that door panel is flat along its length.
Re: '63 to '64 door panel interchange [Re: Montclaire] #1396226
03/08/13 12:20 AM
03/08/13 12:20 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I didn't know that I thought they did exchange from a 63 also I knew for sure a 65 Hdtp door was the same as my 64...
Re: '63 to '64 door panel interchange [Re: ryangtogtx] #1396227
03/09/13 03:55 PM
03/09/13 03:55 PM
Goat330 Offline
Goat330  Offline
The 63 hardtop door will interchange with the 64&65 doors, as will the sedan doors,you could even use the front door panels. The rear door panels are the problem because of the roofline.
