Page 3 of 5 1 2 3 4 5
Re: Revisiting the 383 Stroker Idea [Re: 2fast4yourBrain] #13954
01/18/05 10:18 PM
01/18/05 10:18 PM
Vacaville/ El Dorado Hills ,Ca
440FISH Offline
super gas
440FISH  Offline
super gas
How about Diamond making pistons for the 4.15" crank?
I.e. a 470? Forget the 431!
CH w/4.15" arm and 6.385" short rod is: 1.547".
PERFECT!
Will that work?
with the short rod(6.385) and a big stroke(4.15"-4.25") the pistons might come to far out of the bottom of the bore.
Re: Revisiting the 383 Stroker Idea [Re: 440FISH] #13955
01/19/05 06:30 AM
01/19/05 06:30 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Good question. I would think the counterweights will hit the piston skirt at 4.15.
Back to the questions; yes, we probably will make them with the 1.094 pin, but not this batch. Well over 50% of the people will have either a bushed rod down to .990, or an aftermarket rod.
On the compression ht of the short rod version, I would think 1.730 would be fine.
Re: Revisiting the 383 Stroker Idea [Re: todd440] #13956
01/19/05 06:55 AM
01/19/05 06:55 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, the density of aluminum is 1/3 the density of steel, so the smaller pin has a bigger net benefit.
if you're turning down a 440 crank mains, why not offset grind the throws to chevy journal size to get a 4.28x3.90 B/S and 449 cubes, and get custom pistons made for that?
2017 Grand Cherokee Overland
Re: Revisiting the 383 Stroker Idea [Re: patrick] #13957
01/19/05 07:09 AM
01/19/05 07:09 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Patrick, the stroker piston batch we are making with the 1.320 comp ht for the 440 rod length in the 4.280 bore WILL work with a 6.700 rod and a 3.900 crank.
Re: Revisiting the 383 Stroker Idea [Re: todd440] #13958
01/19/05 10:37 AM
01/19/05 10:37 AM
Wichita Falls, TX
Texas_Jacksons Offline OP
Wichita Falls, TX
All,
There have been some interesting posts about using the 4.15" Crankshaft in the 383. Using the Short 383 Rod may not be feasible, but you could use the Long 440 Rod.
Bore = 4.28" (4.25" + 0.030")
Stroke = 4.15"
Rod Length = 6.768"
Pin = .990"
Compression Height = 1.120"
6.768" Rod / 4.15" Stroke = 1.63 Rod Ratio
Final Displacement = 477.6 cid
And it looks like a seemingly unassuming 383.
Thanks,
Mark Jackson
The Jackson Garage
Thanks,
Mark Jackson
The Jackson Garage
Re: Revisiting the 383 Stroker Idea [Re: Texas_Jacksons] #13959
01/19/05 11:14 AM
01/19/05 11:14 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
All,
Stroke = 4.15"
Rod Length = 6.768"
Pin = .990"
Why do you say that? A 1.12" CH seems unfeasible to me.
A 4.15" crank in a 383 or 400, what's the diff? I've heard of many folks installing 4.15" cranks in 400s (MP makes a crank for such an application.
I haven't heard of any extensive mods req'd to get a 4.15" arm in a 400. 383's the same deck height so it should work w/a 383; just need to find pistons for it.
Re: Revisiting the 383 Stroker Idea [Re: 2fast4yourBrain] #13960
01/19/05 11:57 AM
01/19/05 11:57 AM
AndyF Online content
AndyF  Online Content
If you're going to run a 4.15 or 4.25 stroke crank in a low deck then you'll probably be more successful if you use a chevy pin on the crank and an off the shelf 6.535 chevy rod. The 383 rod is too short to work really well and the 440 rod is too long to fit.
The 383 block, 440 crank, LY rod and short piston combo is a great low buck setup that should really run hard. 10:1 CR with a set of E heads will make a very, very nice motor.
I need to hook up with Todd and get a set of those pistons for a mag article. Maybe throw in a set of Brandon's $400 rods just to see how well they like lots of dyno pulls.
Re: Revisiting the 383 Stroker Idea [Re: 2fast4yourBrain] #13961
01/19/05 12:02 PM
01/19/05 12:02 PM
Wichita Falls, TX
Wichita Falls, TX
As far as your idea of a SR477, I like it. I like everything I have read about building a Short Rod Stroker. But without building one to see if the piston skirt would actually hit the crank, I left those feasibility issues to the engine builders. As far as the LR477, I just went to the Ross Piston website and looked at the 400/499 Stroker pistons. They have a piston P/N:99497 that uses a 6.768" Rod with a 4.15 Crank. It has a Compression Height of 1.120"
Here is the Link.
Ross Mopar Pistons
I figure if it is good enough for the 400, then it is fine for the 383. Will the combination work in the 383? I don't know. Feasible? Maybe.
Thanks for your input.
Mark Jackson
The Jackson Garage
Thanks,
Mark Jackson
The Jackson Garage
Re: Revisiting the 383 Stroker Idea [Re: Texas_Jacksons] #13962
01/19/05 12:15 PM
01/19/05 12:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Here is the Link.
Ross Mopar Pistons
I figure if it is good enough for the 400, then it is fine for the 383. Will it work in the 383? I don't know. Feasible? Maybe.
Mark Jackson
The Jackson Garage
mark , its doable , but thats really a race only piston, its way to short to make a stable long haul piston . also the pin will be in the oil ring , requiring a support rail which will add to the cost.
andy is right on the money , use a 6.535 rod chevy spec rod , the slightly smaller rod end will help in clearing the the oil pickup tube ...
why is it people can't afford to some something right , but they can afford to do it AGAIN ???
Re: Revisiting the 383 Stroker Idea [Re: JohnRR] #13963
01/19/05 01:02 PM
01/19/05 01:02 PM
Wichita Falls, TX
Wichita Falls, TX
All,
This exchange of information is exactly why I started this thread. I have been very pleased that the topic hasn't deviated into using the 400 block instead of the 383. I'm sure that many people out there will use this info to help build their own 383 Stroker combination.
There have been many different combinations discussed, from budget to race. Personally, I'm going to stick with the low budget buildup. I can only afford to build it once, not over and over. I will use good quality parts, but I don't need a set of rods that can handle 650HP or a billet crankshaft. We are building mild, not wild. But if you are building wild, there has been enough information on this topic to assist you.
Thanks everyone,
Mark Jackson
The Jackson Garage
Thanks,
Mark Jackson
The Jackson Garage
Re: Revisiting the 383 Stroker Idea [Re: Texas_Jacksons] #13964
01/19/05 01:11 PM
01/19/05 01:11 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Yes, I have been happy with the info too. Usually it does turn into building a 400 or 440 block.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Revisiting the 383 Stroker Idea [Re: Texas_Jacksons] #13965
01/19/05 01:28 PM
01/19/05 01:28 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
the biggest pain in this whole idea is the lack of off-the-shelf pistons, but yes, this has been a serious learning experience on getting the right combo of R/S ratio, CH heights, comp. ratio, etc., etc.
Since there hasn't been too many engine builders doing this combo, we're all in the theoretical stage it seems like.
Does anyone have a spare stock rod and piston they care to "donate" so I can mock up my engine w/the 4.15" crank to see if there's any interference?
I'm definitely going w/that crank; it's just a matter of what rod to go with: 6.358", 6.385", 6.535" BBC (but definitely NOT the 6.76" RB rod). Then from that, I can figure out how to order custom ($$$???) pistons.
Hoping the whole rotating mass to be under $2k.
Re: Revisiting the 383 Stroker Idea [Re: 2fast4yourBrain] #13966
01/19/05 01:43 PM
01/19/05 01:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
if no one local steps up i am pretty sure i have a piston and a rod , pay the shipping .
Re: Revisiting the 383 Stroker Idea [Re: JohnRR] #13967
01/19/05 05:41 PM
01/19/05 05:41 PM
I have a early 60's 383 and a 77 400. One of them is going to be a stroker. I am not trying to turn this into a 400/451/??? combo post. I just want to know what advantages there might be in using the 383 rather than 400. Advantages for 400 are stronger block and cheaper and plentifull pistons for a bunch of combo's. Also MAYBE the bigger bore is an advantage. But maybe not on the bore. Some talk about the smaller bore having better "full combustion...flame travel fuller and faster...". What advantages exist in the 383 stroker. The 4.15 is a little long I think but how about any advantage in 3.90 or stock 440 crank over the same in a 400?
Re: Revisiting the 383 Stroker Idea #13968
01/19/05 06:49 PM
01/19/05 06:49 PM
Wichita Falls, TX
Wichita Falls, TX
I was afraid that was going to happen. Just kidding. I'm sure some other "experts" will chime in later. I'm not an expert, but I do have some data that may help your decision.
From the Mopar Engines Manual:
The 1976-1977-1978 blocks for the 400 and the 440 are a thinwall casting design. As such they shouldn't be overbored more than .020".
Now most people will say that the only true way to tell is to have your block sonic tested, before you build it. I’m just giving you the info that I have.
As far as other factors for your decision, cost is not one of them. It will cost you roughly the same amount of money to build either the 431 or the 451. The only difference is the cost of the Piston and Rings, but that may not be enough to worry about. The weight of the Rotating Assembly would be slightly different, but is it enough to make the decision? Then is comes down to cubes, 20 more at 1hp per cubic inch is 20HP. It is just an example guys, so don't tell me that it will make more or less than 1hp per in3. It is an example.
Opinions?
Mark Jackson
The Jackson Garage
Thanks,
Mark Jackson
The Jackson Garage
Re: Revisiting the 383 Stroker Idea [Re: Texas_Jacksons] #13969
01/19/05 07:16 PM
01/19/05 07:16 PM
""The 1976-1977-1978 blocks for the 400 and the 440 are a thinwall casting design. As such they shouldn't be overbored more than .020".""
If you check out the tech section here on sonic testing you will find that the thin wall therory has been pretty much proved wrong, and also the lower end strength around the mains (tech section from 440source) is considerably better on the later 70's blocks than on earlier blocks. Also some block ribbing improvements made later too.
Re: Revisiting the 383 Stroker Idea [Re: AndyF] #13970
01/19/05 08:39 PM
01/19/05 08:39 PM
Gambrills, Md
mopork Offline
mopork  Offline
Gambrills, Md
Who would you guys suggest to turn down the crank for these stroker combos ?
Re: Revisiting the 383 Stroker Idea #13971
01/19/05 08:48 PM
01/19/05 08:48 PM
OK, I'll be the guy in the flame suit and ask the question - Why alter the short stroke (oversquare)design of the engine? Conventional thought says to use as large a bore as possible (in combination w/short stroke) for high RPM power, e.g. F1, Indycar, motorcycle engines, etc. Would it be cost-prohibitive to enable to motor to rev to 8000rpm reliably, using a stock prepped 383 crank, GOOD quality aftermarket rods, lightweight pistons, and solid cam instead of spending the money on stroking? This would not seem a bad idea, especially in a lightweight car with 4.10/4.30 gears. I am just throwing this out there for an opinion from the builders, not trying to argue the merits of stroking the 383 (which sits in my Duster with a broken valve).
Re: Revisiting the 383 Stroker Idea [Re: mopork] #13972
01/19/05 09:02 PM
01/19/05 09:02 PM
440FISH Offline
super gas
440FISH  Offline
super gas
block info.
Go read this if you have not read it yet. My take on the main bearing area is that maybe Chrysler thought the later cast cranks would flex more or could not handle the flexing like the forged cranks. So they made the block a little stronger to hold the crank better. As for the 383 block being the thinnest, it also has the biggest crank journal overlap.
Re: Revisiting the 383 Stroker Idea #13973
01/19/05 09:07 PM
01/19/05 09:07 PM
440FISH Offline
super gas
440FISH  Offline
super gas
Not everyone wants a 8000rpm screamer. Have you ever had a car that makes all it’s power up top(4000+) It gets old fast. So the stroker brings the same power but at a much lower and useable rpm…
