Re: rod length for a rb?
[Re: 68roadrunner]
#1395848
03/02/13 02:45 AM
03/02/13 02:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I went with a 6.8 GRP alum rod on a 514... with CP pistons for a light weight package(was going to turn it 9000+) with B1M/C heads
[Re: Cab_Burge]
#1395850
03/02/13 10:09 AM
03/02/13 10:09 AM
Posts: 877 ky
68roadrunner
ky
Which rod journal size and stroke are you wanting the rods for? I like and use the longest rods I can use in any Mopar B, RB and Hemi strokers motors I build
the 2.2 journal makes a lighter rod, so thats what i am looking at. either the 4.150 or 4.250 stroke.
[Re: 68roadrunner]
#1395851
03/02/13 10:38 AM
03/02/13 10:38 AM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Is this setup for a stock block? I run a center counter weighted crank with the express purpose of reducing cap walk and stress on the block. It worked on my mega block and I am sure it would help a lot to reduce stress on a stock block too. If you want to get the lightest combo, you can go down to a 2.100 chevy small block bearing for an even lighter set up. That would require a custom aluminum rod I believe, but you could go as long as you like. A piston with a 1.200 compression height would need a rod 7.375 long and the whole deal would be VERY light! Nascar and Pro Stock run smaller bearings than that, but you probably want to have better service life than they require. I mention a 1.200 compression height because piston stability might become a problem with a shorter piston. But you can go as short on compression height as the piston maker says will work well, and then custom make the rods to fit. Their are shelf stock 1.12 pistons out there, which would need a rod that is about 7.455 long. The limiting factor is piston compression height.
[Re: 68roadrunner]
#1395853
03/02/13 12:30 PM
03/02/13 12:30 PM
gregsdart
My info on the 2.100 bearing crank comes from Crower, plus previous builds. I have run 7.1 x 2.100 bearing aluminum rods. The crank with a 2.100 journal will last a long time according to Crower. Same with the rods. On the crank, you can order one built, or offset grind a 2.2 or even a 2.375 crank provided you have a knowledgeable machinist elongate the oil holes to position them on the rod journals after the regrind. There will be no clearance problems with the rods until the stroke gets very long, (except bore notching) like 4 .75 inch or more.
