Best Spark plug for 509 mopar cam 440+6 ???? #1395742
03/01/13 07:52 PM
03/01/13 07:52 PM
IN
Dartman928 Offline OP
IN
Need some suggestions what plug to use in a 440+6 509 mopar cam 10:1 ported 906 head engine Going to be street only.
Thank you
Re: Best Spark plug for 509 mopar cam 440+6 ???? [Re: Dartman928] #1395743
03/01/13 08:36 PM
03/01/13 08:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I always ran Champion RJ12YC.
worked great!
Re: Best Spark plug for 509 mopar cam 440+6 ???? [Re: Dodgem] #1395744
03/01/13 09:21 PM
03/01/13 09:21 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Champion J12Y is the best I've found.
Re: Best Spark plug for 509 mopar cam 440+6 ???? [Re: Dartman928] #1395745
03/01/13 09:42 PM
03/01/13 09:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
Thank you
I would look at and use both the Autolite 74 or #AR73 or # 84 or 83(Autolite resitor plugs with the asme heat range as the 73 and 74), if available, and the Champion RJ10YC Colder heat range is better when using a iron head and pump gas like your talking about
Re: Best Spark plug for 509 mopar cam 440+6 ???? [Re: Cab_Burge] #1395746
03/01/13 10:17 PM
03/01/13 10:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used Autolite 74's in my old 906 headed .557 cammed 440. Ron
Re: Best Spark plug for 509 mopar cam 440+6 ???? [Re: Dartman928] #1395747
03/01/13 10:33 PM
03/01/13 10:33 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Best option is use NGK R5670-5...I use these NGK series plugs in all builds and they offer them in multiple heat ranges for diff applications , cr, etc.
Yep, they are Japanese, but very high quality.
MB
