275/60/15s on a 67-69 Dart??? #1395717
03/01/13 06:54 PM
03/01/13 06:54 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Will a 275/60/15 fit in a 67-69 Dart rear wheel well with just doing the 3/4" offset and without mini-tubbing?
Re: 275/60/15s on a 67-69 Dart??? [Re: mopowers] #1395718
03/01/13 08:04 PM
03/01/13 08:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Yes, but you may have to move the rear end back. I had to move mine back 1/2".
Re: 275/60/15s on a 67-69 Dart??? [Re: mopowers] #1395719
03/01/13 08:41 PM
03/01/13 08:41 PM
smyrna,tn
draginmopars Offline
smyrna,tn
Don't know about 67-69
72,stock, No offset or mini tub
we wanted to use the ones that were on it.
So we put on these temp tires.
to keep it rolling til body repair/paint
Side walls are NOT rubbing
It's just marks, from being stacked/stored,in the barn.
4"backspace
Front 255-60-15
Rear 275-60-15
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 275/60/15s on a 67-69 Dart??? [Re: draginmopars] #1395720
03/01/13 09:36 PM
03/01/13 09:36 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
If you are going to run a drag radial they will not fit, been there done that.
Re: 275/60/15s on a 67-69 Dart??? [Re: Darryls-Demon] #1395721
03/01/13 10:40 PM
03/01/13 10:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My MT ET Street Radials did, stock A body 8 3/4 with Moser axles and weld 15 X 8 with a 4.5" back space. Off set springs and the rear end moved back 1/2". I did trim the wheel well lip some.
Re: 275/60/15s on a 67-69 Dart??? [Re: justinp61] #1395722
03/02/13 04:10 PM
03/02/13 04:10 PM
Glendale Az
Glendale Az
I wish that was all I needed to do was trim the lip a little.
Re: 275/60/15s on a 67-69 Dart??? [Re: Darryls-Demon] #1395723
04/05/13 04:39 PM
04/05/13 04:39 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Just a quick update...
The tire shop mounted one 255/60 and one 275/60, to see which one fit better. Sure enough, the 275 had plenty of clearance! I had Wheel Vintiques make a 15 x 7 with a custom 5" backspacing. I have nothing but things to say about them. The wheels were straight and true and it only took the 1.5 weeks to get them to me. Other than the custom BS, I did move the springs in 1/2". I have 1/2" clearance on both sides. Hopefully that'll be enough...
I spotted the tire guy an extra 20 for letting me try both size tires. Believe it or not, I still have about 3/4" front clearance with the 275's.
