Help windshield for 66-70 b-body sedan un-available.
#1395675
03/01/13 05:31 PM
03/01/13 05:31 PM
Posts: 2,345 west palm beach, florida
modelmakerinc
Like the topic says, I just found out that the 66-70 2 door sedan/ post or four door B-Body Coronet/ Belvedere is no longer available.
This means that it needs to be purchased used, and good luck to us finding one in good enough condition for our restorations.
Anybody have any suggestions?
PM me if you have one you are willing to part with. Thanks Henry
Re: Help windshield for 66 67 b-body sedan un-available.
[Re: modelmakerinc]
#1395676
03/01/13 05:40 PM
03/01/13 05:40 PM
Posts: 5,163 CT
GTX MATT
CT
I find that hard to believe (actually no I dont), its the same windshield in 68-70 B body 4 doors and convertibles.
[Re: GTX MATT]
#1395677
03/01/13 05:48 PM
03/01/13 05:48 PM
modelmakerinc
The model years are 66-70 B-Body. four door, 2 door post or Sedan and Wagon. Verts and hardtops are different
Windshield part number DW672 is no longer available new.
I have called half a dozen glass shops locally and several parts vendors like Stephens, Herbs, ect. and no-one has availability.
[Re: modelmakerinc]
#1395678
03/01/13 06:02 PM
03/01/13 06:02 PM
Posts: 5,163 CT
GTX MATT
CT
That doesn't make sense, I think they've got their part number wrong. 1966-1967 2 door, 1966-1970 4 door, and 1966-1970 convertible should all be the same I believe. 1968-1970 2 door is different. Could be the first time I'm ever wrong though it had to happen eventually
[Re: GTX MATT]
#1395679
03/01/13 06:03 PM
03/01/13 06:03 PM
Posts: 18,157 Mass
DAYCLONA
Mass
IF so, the 66-70 B body vert windshield still shows available from www.metropartsmarket.com pn# CG DW671-pro5 #250 blue or green tint
[Re: Black_Bee]
#1395682
03/01/13 06:24 PM
03/01/13 06:24 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
No guys the Convertibles and Hardtops are the same glass.
two door post Sedan four door and the wagon
just think for a moment the way the glass and the vent window are the post cars have a fixed frame on the door the hardtop and vert's have the vent window only
As others on here have said (for 68-70 anyway, 66-67 is likely different) the windshield is the same whether its a 2-door post or hardtop... my '69 Bee post doesn't have door frames and pretty much identical to a hard top and is not like the post cars of previous years.
I bought my windshield gaskets brand new from a Moparts vendor.
yes it is but a 66-67 2 door SEDAN is different , it has a full post around the door glass like a 4 door sedan and uses a different ... TALLER ... windshield , convertibles use the 4 door sedan vent window but I'm pretty sure it uses the hardtop windshield.
[Re: modelmakerinc]
#1395683
03/01/13 06:27 PM
03/01/13 06:27 PM
Posts: 167 maryland
74yellowduster
maryland
you should call AMD and ask them if they have any still in production. they sell most of the different mopar glass. 866 591 8309 if not maybe they can give you a lead to someone who might have something. www.autometaldirect.com
[Re: Black_Bee]
#1395684
03/01/13 06:30 PM
03/01/13 06:30 PM
modelmakerinc
I did Call, been looking into it all day AMD does not have it either.
OK, The term: post or sedan, is where the difference can be confusing.
the 68-70 B-Body Post cars were different in the configuration to the 66-67 B-Body Post
66-67 four door and wagon, 66-67 two door sedan, 68-70 four door and wagon.
the 68-70 post cars use the same glass as the hardtops and verts.
[Re: modelmakerinc]
#1395687
03/02/13 01:12 AM
03/02/13 01:12 AM
Posts: 4,872 connecticut
pnypwr
connecticut
according to the hollander interchange in 66 and 67 the 2 door hardtop uses 2906 as does the convertible the 2 dr sedan 2907 as does the 4 door.
68 to 70 sedan and hardtop 2 door uses a 3303 conv 2906 and 4 dr sedan and sta wagon use 2907 the 2 doors windshields are the same except convertible
this is from the hollander interchange 39th edition
fwiw there is a guy advertising on the ct and ri craigslist that has a warehouse of obsolete glass he may be able to hook you up
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: boydsdodge]
#1395689
03/02/13 12:28 PM
03/02/13 12:28 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Try Bob's Classic Auto Glass, they got me a windshield for my 67 Dart Sedan after I tried getting one at every glass shop in Canada and a bunch of glass suppliers on this site. Now it was not cheap ( close to $ 700 by the time they shipped it to Canada ) but it in much better than getting bugs in my teeth.
A new iron curtain drawn across the 49th parallel
