install motor & trans together ???? #1395543
03/01/13 02:43 PM
03/01/13 02:43 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I'll be re-installing the 452 & 727 into the Satellite sometime soon. I've never tried mating them up and installing together. easier? harder? should I drop them in together, or motor first, then trans from below?
Thanks-
Re: install motor & trans together ???? [Re: StealthWedge67] #1395544
03/01/13 03:07 PM
03/01/13 03:07 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I find it easier to set the trans in then put the motor in FWIW
Re: install motor & trans together ???? [Re: StealthWedge67] #1395545
03/01/13 03:18 PM
03/01/13 03:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks-
The job is MUCH easier to put them in together...
BUT you HAVE to have a engine leveler...put it in
level going over the rad yoke then start tipping it
then as the engine clears the yoke start to level it...
I do it all the time in my much smaller cars with
no problems
http://www.summitracing.com/parts/sum-g1022
Re: install motor & trans together ???? [Re: MR_P_BODY] #1395546
03/01/13 03:31 PM
03/01/13 03:31 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I find it much easier to install them together.
I have done it without an engine leveler, but it makes it easier if you have one. Got my leveler from Harbor freight.
Re: install motor & trans together ???? [Re: Dodgeguy101] #1395547
03/01/13 04:28 PM
03/01/13 04:28 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I put them in together. I raise the REAR of the car as high as possible, with the front wheels on the floor. Get the motor/trans, headers, etc in and on the mounts. Then unhook/remove the engine hoist and raise the front of car on jackstands to hook up everything else. The engine leveler is VERY handy.
If you like drag racing, support your local track.
Re: install motor & trans together ???? [Re: Dodgeguy101] #1395548
03/01/13 04:29 PM
03/01/13 04:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Most of the time, I do them together; easier to look everything over and deal with the flex plate/converter/clutch. I use a leveler but have done it the hard way when I had someone around to help. I cover the aprons, rad support & firewall with moving blankets, wrap a towel around the tailshaft, put a floorjack under the car where the trans is headed, and get the rear axle up on jack stands to improve the angle. I lay the headers against the blankets covering the aprons and bungee them up.
Re: install motor & trans together ???? [Re: topside] #1395549
03/01/13 04:40 PM
03/01/13 04:40 PM
Puyallup, WA
Puyallup, WA
Sounds like I'll have a go at it with them together. I do have a leveler. Certainly will make the alignment and bolt-up of the trans to the motor much easier.
Raising the rear end seems like a good trick, offering a better angle.
Thanks guys.
Re: install motor & trans together ???? [Re: StealthWedge67] #1395550
03/01/13 06:25 PM
03/01/13 06:25 PM
I've done it both ways On my Duster I always put the motor in first with the car raised up on jackstands and then installed the tranny from the bottom. I didn't want to scratch up the firewall and that motor was set way back from stock location, it had a stock firewall also lots of wys to skin the kitty
Re: install motor & trans together ???? [Re: Cab_Burge] #1395551
03/01/13 06:49 PM
03/01/13 06:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do it the same way. Once the eng is hooked to the eng mounts I leave the eng hanging on the hoist while I go under the car with the trans on a floor jack and slide the trans in then bolt the trans crossmember in. Ron
Re: install motor & trans together ???? [Re: 383man] #1395552
03/01/13 08:08 PM
03/01/13 08:08 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I agree, you can do them together if you have a helper or two, but if working alone I prefer engine first, then trans.
Re: install motor & trans together ???? [Re: cgall] #1395553
03/01/13 10:17 PM
03/01/13 10:17 PM
maryland
74yellowduster Offline
maryland
an interesting way to do it from underneath...
page 28 of this thread:
http://www.forabodiesonly.com/mopar/showthread.php?t=111128&page=28
about a third of the way down the page the pics start
Re: install motor & trans together ???? [Re: 74yellowduster] #1395554
03/01/13 10:34 PM
03/01/13 10:34 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I started doing all of mine from underneath. If I never have to do one over the fenders again it will be too soon. Its really much easier than it sounds. Best thing is you can assemble EVERYTHING on the K frame and then roll it right under and lower the car down. Install t-bars, steering column, upper ball joints, and most of the underneath work is finished.
...FAFO...
Re: install motor & trans together ???? [Re: skicker] #1395555
03/01/13 11:07 PM
03/01/13 11:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In a small car like mine with a tube chassis .. I or
you will NEVER get it in there... I dont even think I
can pull the trans from the bottom.... anyone with
a stock body and still has the K in the car will NOT
have any problem... I pull my engine and trans as a
assm all the time(maybe 2 times a year) and I dont
even bump anything(and my dist is 1/4" off the firewall)
and thats always doing it myself.. yes if you hav the
K-member out and want to stuff it in (all together)
it works great with a hoist and a platform so it sits
on it.... its up to the person I guess
Re: install motor & trans together ???? [Re: MR_P_BODY] #1395556
03/02/13 01:13 AM
03/02/13 01:13 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I have a dolly that was made to roll engines around on. I guess its about 18x18 or so. It has slide rails that line up with the bolts on the bottom of the oil pan rail. The oil pan is about 6" off the floor when on the dolly. Once the long-block is completed I can attach the k frame with the steering box, the idler arm and drag link. I bolt up the trans and converter along with the trans mount. Bolt on the starter and headers,followed by all of the kickdown linkage, starter lead and trany lines. I use the engine crane with a pipe under the front frame rails between the bumper brackets to lift the front end. Rear wheels are on the ground. You can roll the whole assembly in from the side only lifting the car high enough to clear the distributor under where the upper control arm bolts on. Lower the car slowly and the trans mount gets the four bolts installed. Lower it down further and install the 4 k frame bolts. Slide the LCA's with the strut rods in and hook up the torsion bars. UCA's are already on car with spindles and rotors attached. You don't have to re-bleed the brakes this way. Bolt the front shocks up and install the steering column and linkages or shift cables. Pop in the driveshaft and your all but done underneath. Worked great on my 70 Satellite with a 383-727. I hope it works equally as well in a couple weeks with a 340-727 in the 69 Dart.
...FAFO...
