Hemi guys - Hemi Header collector qun #1395470
03/01/13 09:54 AM
03/01/13 09:54 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Guys I can fit 2.25" TTI headers into my car easily enough.
My question is: will a 3.5"collector be enough for a 6500rpm max 572" N/A Hemi ? Engine makes 845HP/770TQ on pump gas.
TTI make a 4" collectored header but that is only for the Indy 426-1RA head, and Im running a set of Indy 426-1 head.
So, am I better off with a 4" collector or will 3.5" be sufficient ?
Any experience with this would be great !
Thanx
Re: Hemi guys - Hemi Header collector qun [Re: LAD 524] #1395471
03/01/13 01:30 PM
03/01/13 01:30 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
are you running mufflers ? if so what size pipe and mufflers
home of the
Sox and Martin Hemi Duster
Re: Hemi guys - Hemi Header collector qun [Re: HEMIFRED] #1395472
03/01/13 06:33 PM
03/01/13 06:33 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
in my opinion, 3.5 is way too small for a 572. with a 426/7200 rpm/765 hp motor w 2.25 primaries, we saw 8HP improvement w 4" vs 3.5"
Be a Rebel- Break the Laws of Physics!
Re: Hemi guys - Hemi Header collector qun [Re: mbogina] #1395473
03/01/13 11:26 PM
03/01/13 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
... I run a 3.5" on my SB.... you need 4" or
possibly more(dependent on the revs)
Re: Hemi guys - Hemi Header collector qun [Re: MR_P_BODY] #1395474
03/02/13 12:28 AM
03/02/13 12:28 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went with 4 inch stanless with an X pipe and out the back bumper.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi guys - Hemi Header collector qun [Re: hemi-itis] #1395475
03/02/13 01:04 AM
03/02/13 01:04 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Hey can we see the rest of that 63 ? That looks really nice . Gary
Re: Hemi guys - Hemi Header collector qun [Re: Gabby63] #1395476
03/02/13 02:11 AM
03/02/13 02:11 AM
hemi-itis Offline
hemi-itis  Offline
Sure gary!
Re: Hemi guys - Hemi Header collector qun [Re: hemi-itis] #1395477
03/02/13 08:22 AM
03/02/13 08:22 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx pretty much confirmed what I suspected.Here's my plan....
Since TTI don't make a 4" collectored header for the 426-1 heads I think Im gonna have to mod them and add the 4" collector.
Then dual 4" pipes from the collector to the X (or H) then muffs - 4" IN and 3.5" OUT. The reason for 3.5" out is by then the exh gases would have cooled sufficiently to allow a reduction in pipe diameter and to enable it to be easier to get over the diff.
After they go over the diff Ill run another 2 x 3.5" IN/OUT muffs at the rear to keep the noise to an acceptable level. The tank is in the trunk so I have the room to do it. The dual 3.5" pipes out to the bumper.
For you 4" collector guys, how is your ground clearance with them?
Thanx...
Re: Hemi guys - Hemi Header collector qun [Re: LAD 524] #1395478
03/02/13 09:49 AM
03/02/13 09:49 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
With all the trouble to go threw you think you will ever feel that maybe 8 HP loss on a street car???? You already have more than you need!!!! Just my 2cents.
JAKES AUTOMOTIVE
Re: Hemi guys - Hemi Header collector qun [Re: JAKE68] #1395479
03/02/13 12:02 PM
03/02/13 12:02 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Jake just want to optimize the combo amigo - thats all.
BTT
Re: Hemi guys - Hemi Header collector qun [Re: LAD 524] #1395480
03/02/13 09:58 PM
03/02/13 09:58 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
BTT
8 HP loss on your combo should ony be about 1%.
you will never see any difference
home of the
Re: Hemi guys - Hemi Header collector qun [Re: HEMIFRED] #1395481
03/02/13 11:55 PM
03/02/13 11:55 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'd run it as is. My engine's headers are 2 sizes small on the primaries and 1/2" or better to small on the collectors. It still makes more power than I've been able to stick to the ground. The only time I can notice the difference is with the mufflers and pipes hooked up, I loose 117hp then. As Fred said, you'll never see the difference in 8hp. Dave
Re: Hemi guys - Hemi Header collector qun [Re: hemi-itis] #1395482
03/03/13 01:08 AM
03/03/13 01:08 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Hey thank you , very nice lookin car . has it seen the track ? Or just a weekend cruiser . Gary
Re: Hemi guys - Hemi Header collector qun [Re: quickd100] #1395483
03/03/13 01:30 AM
03/03/13 01:30 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thats just it Fred.
I want to run thru the exhaust at the track as well.
Re: Hemi guys - Hemi Header collector qun [Re: LAD 524] #1395484
03/03/13 09:53 AM
03/03/13 09:53 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Another vote for 4".
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Hemi guys - Hemi Header collector qun [Re: DusterDave] #1395485
03/03/13 10:08 AM
03/03/13 10:08 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Unless you are trying all different exaust combo's and measuring results you have no idea what your gains or losses are. That 8 hp loss was on someone else's combo. you dont have a clue what yours are. It may make less but make more torque. Unless you are running a heads up class just adjust the hp loss with the dial in on the window. That is allot of expence for the small gain.
JAKES AUTOMOTIVE
Re: Hemi guys - Hemi Header collector qun [Re: JAKE68] #1395486
03/03/13 02:35 PM
03/03/13 02:35 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We have to run full exhaust in our KOS series here, so we have played around a lot with our exhaust. Not to say we know everything, but in my experience the exhaust system is way more of a power robber than the headers themselves.
We have tried a lot of different exhaust combos on the Cuda and in the end I just put electric cut-outs on it. That way it is quiet enough to keep the cops off my butt while in town.
3 1/2" or 4" exhaust was just so large, cumbersome and expensive, that it was just not practical. Besides, no matter what I tried, it robbed HP. And a lot more than 8 HP.
I run 3 1/2" to the dumps and then 3" on out the back. Much easier, cleaner, cheaper and no clearance issues. Besides, I can make it as loud as I want any time I want.
Master, again and still
Re: Hemi guys - Hemi Header collector qun [Re: DaveRS23] #1395487
03/04/13 02:07 AM
03/04/13 02:07 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Good info fellas.
Dave, Thats what Im planning to do if I stick with the 3.5" collector run 3.5" pipe to the mufflers then after the mufflers when the gases have cooled sufficiently, step down to 3" over the rear end then another pair of 3" in/out mufflers at the rear of the car for further noise control as I have the space. I may also experiment with alum tubing and possible oval tubing and use electric cutouts to further reduce the noise if reqd.
Here's food for thought, I just confirmed with my dyno guy, the combo made 850HP at 6300rpm and 770TQ at 5300rpm with 2 1/8" Dyno headers with a 3.5" collector
Interesting.
Re: Hemi guys - Hemi Header collector qun [Re: LAD 524] #1395488
03/04/13 10:55 AM
03/04/13 10:55 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Just to be clear; I run 3" after the cut-outs. With the cut-outs, the extra 1/2" exhaust pipe diameter just doesn't matter. I can crack open the cut-outs just a little and get the same results without being too loud if I want.
With cut-outs you can concentrate on the exhaust system's cost, fit, and sound. Instead of the quest for maximum flow causing all kinds of problems.
And did I say how much FUN cut-outs are? I will never have another muscle car without them.
